Kiwi Fruit
Introduction: Kiwi Fruit
My skateboard is inspired by kiwi fruit, which is a surprise fruit with progressive taste. I hope that the skateboard I made can provide users with handy and surprising experience.
Tinkercad created this refreshing look.
Teacher Notes
Step 1: Make a Skateboard Board
To make the board face of skateboard, first of all, my keynote is to build a beautiful curve skateboard, so the work on the board is great.
After a series of difficult operation, give it pure and fresh and elegant color again, a concave and convex surface is finished
Step 2: Making the Bottom of the Skateboard
After the plane design, make the bottom of the skateboard, choose two cuboid blocks of different sizes and make them. The design of the bottom of the skateboard should focus on firmness and stability, and the safety factor should be high.
Step 3: Do the Roller Skating Part
Do roller skating part, select two different lengths, different sizes of cylinder, the two ends of the connection
Step 4: Making the Wheels
Then the bottom is completed, the wheel part is made, and the wheel is going to make it slide
Step 5: Connect the Wheels to the Bottom
After the wheel is embedded in the catheter, make a connection between the bottom part and the skateboard surface
Step 6: Making the Whole Fit
Finally, four wheels to do four decorations, do the final step of the decoration, and then do four connecting columns, the skateboard surface and the bottom of the welding together
Step 7: Final Rendering Diagram
Final skateboard finish diagram
In this sad and lonely season of autumn since ancient times, may this touch of green bring some autumn scenery better than the spring dynasty
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
