Knex Pistol: Winona V1.0
8,706
19
112
For the new improved version go to: https://www.instructables.com/id/knex-pistol---Winona-v3.0/
This is my attempt at a K'nex gun, dubbed Winona. After having read a few others, let me say a few things first.
I apologize for the picture quality ahead of time.
I am posting exactly how I made it, but there are a great many pieces that are there simply to make it look good or keep things from sliding around. I did not use any "exotic" pieces, all of the ones I used came from two of the "value tubs" of 400 pieces that I purchased at Wal-Mart for approximately $20 apiece.
Ammo loads in the front. It will shoot anything you can fit in there. The only problem (concerning the ammo) is that it doesn't stay in if you tilt it. I am hoping someone will solve that little dilemma and post their own version or a picture in the comments.
Power is of course dependent upon the strength of your rubberbands. You don't really need too strong of one for the trigger, but you will want a pretty strong one for the firing pin.
Anyway, I welcome any thoughts, suggestions, questions, etc... and I hope you enjoy.
Teacher Notes
Step 1: Parts.
I used a crapload of the red connectors. Also, I counted this up after the gun was constructed, so there may be a few errors.
I suggest looking at all the pictures for all steps before building, some of them do not show all the parts as well as they should during each step (such as the handle) but show better views in other pictures.
Step 2: Construct the Barrel.
This thing is a pain to assemble as you start getting to the end of the barrel.The majority of it consists of red connectors with gray rods through either end. The pictures show spaces and the way it is setup to accommodate the trigger and other bits. Most of the front end isn't necessary but I thought it looked good, and it added some space to work with in case this ended up going from a pistol to a rifle.
Step 3: Construct the Handle.
The handle is a pain in the rear as well, but it works fairly well.
Step 4: Construct the Trigger.
Here is the trigger.
Step 5: Construct the Firing Pin.
Pretty straightforward.
Step 6: Assembly.
Time to start putting crap together.
Step 7: Finish!
Pull back the firing pin, the trigger will set, insert your ammo, and pull the trigger.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
    112 Discussions
    devlyn.slyte
    4 years ago on Introduction
    The Barrel was too hard for Me. After about 2 Class Hours I have given up. Which is really Upsetting because I want to make this,
    skater builder guy
    9 years ago on Step 2
    how the hell are you supposed to make that you should show the construction of the barrel
    jboppx22
    11 years ago on Introduction
    o junk, that thing looks awsome, i'm not some knex nerd but i make these in my free time, this looks cool tho
    J Moneymanjboppx22
    we're not nerds, were highly intelligent engineers that use children toys to make deadly weapons. :)
    jboppx22J Moneyman
    good defence. yea, when you can make ones these powerful, you have to be a highly intelegent engineer. i bet you cause kill someone with a sharpened one. lol
    cobraSeMi_AuToMaTic
    Reply 11 years ago on Introduction
    you should put a hook on each ram so you can load both guns, at the same time, without your fingers leaving the trigger.
    to solve the problem for anyone with exotic pieces use the black ball joint connector (the one that holds the ball) and put it in a spare part of the magazine, the connector will clip the ammo in place and will reduce the velocity only slightly.
    mrbox
    I still cant seem to build the barrel =( someone helps me it was my second knex gun well was gonna be... Im planning to build old guns i thought i was gonna make cause they seem to be better than the new versions ;D
    madeup7777777mrbox
    yeah. its hard but i built it in an hour due to the angles of the pictures. he should put a video on here
    mrboxmadeup7777777
    I made both already... its been a month =) I prefer the old one cause the red rods dont bend as much =)
    plspls
    i just read about your "problem" i put a ball socket joint near the end of the firing pin and locked the ammo in there.
    mrbox
    Forgot to comment... GREAT GUN =) amazing
