Korean Drama Inspired Hairpin
161
Introduction: Korean Drama Inspired Hairpin
Hello everybody this is my first instructable. In this I design a Korean drama inspired hair pin.
I had a piece of jak wood cut off from another project I did before, and I decided to make a hairpin out of it.
Materials used
  • Piece of jak wood
  • Jigsaw
  • Rotary Tool
  • Sanding paper
  • Water based wood stain
  • wood polish
Teacher Notes
Step 1:
First I cut the piece of wood in the shape of a square and stick with a jigsaw. Then I can draw a design on the square part.
Step 2:
After cutting the shape I scraped off the wood from around the stick part equally from all directions from a cutter so that the stick is coming off right from the middle of the square.
Step 3: Carving
Then I use my rotary tool to carve a simple design on the square part. I use various types and sizes of burrs and sanding drums to carve out the design.
Step 4: Sanding
Then I use the sanding paper going from a high grit value to a lower one. Again rounding off the petals and the leaf as I smoothen it.
Step 5: Dusting
Then I use the brush bit with the rotary tool and take off any dust on the hairpin. Make sure to clean it thourougly otherwise it wood leave bums when polishing.
Step 6: Staining
Then I apply two coats of wood stain to the hairpin and leave it off to dry.
Then I again use the lowest grit sand paper on it. After dusting it off I applied two coats of water based wood stain on it until i get the desired colour.
Step 7: Polishing
After it is dried off I mixed a little amount of wood polish and thinner to a consistency where I can apply it easily without having clumps.
Step 8: Adding Stones
Woodworking Contest
Woodworking Contest
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    2 Discussions
    seamster
    seamster
    1 year ago
    This is a very impressive hairpin. Nicely done on the intricately carved details!
    RadhaS4
    RadhaS4
    Reply 1 year ago
    Thank you very much seamster
