LCD Display 16x2 on 3.3V
A quick project for a rainy sunday afternoon.
More and more devices will work on 3.3V or even less and do not tolerate and supply 5V. Unfortunately one of my favorite "development tools", the 16x2 lines character LCD also needs 5V to display anything.
I like to use this LCD during development to display the value of variables or other debug info.
Supplies:
LCD 16x2 (Ebay)
74HC14 (Mouser, TME)
few diodes, resistors and capacitors (Ebay, Mouser, TME)
small perfboard (Ebay)
Teacher Notes
Step 1: A Few Volts Negative
So I did some testing on these Hitachi HD44780 LCD controllers (or compatibles) and it appears that they work fine at 3.3V but the LCD itself does not. To show anything there has to be a sufficient voltage difference for the liquid crystals to react.
I supplied the display with 3.3V and put a small *negative* voltage to pin 3, normally called Vo or VE, the Contrast Voltage. And then it does display your text.
Generating a small negative voltage is easy, just take a square wave and feed it into a negative voltage multiplier. Most of the time you will have a spare pin (GPIO) left on your micro controller on which you can produce a squarewave.
But I wanted a "standalone" LCD that I can plug in to a project under development so I took a 74HC14 (hex inverter) and made a square wave oscillator with it. The inverting voltage multiplier takes care of producing a few volts negative.
Step 2: On 3.3V
There you have it, a 16x2 LCD working on 3.3V supplied by the Nucleo board.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    2 Discussions
    kiwigrinder
    Tip 23 days ago
    Most 1602 LCD boards already support running at 3.3V. If you look at the back of the board, you will notice some pads for missing components. By soldering a ICL7660 or MAX660 for U3 and two 1206 10uF caps for C1 & C2, removing the solder from jumper J1 and soldering a bridge between J3, you can run your LCD from a 3V3 supply. The extra components create a charge pump that generates a -2V supply for the LCD from the 3V3 supply.
    WilkoLkiwigrinder
    Reply 23 days ago
    Interesting! I checked and I do have two of those LCD boards. I'll buy two of those ICL7660's at TME (the MAX660 is far more expensive there) and give it a go. Thanks!
