LED Birthday Cake Candle That You Can Blow Out
About: There is nothing to know about me i might just right a instructable or two.
I am going to show you how to make a birthday candle that uses an LED but you can still be blown out.
Inspired by electronic_plumber An LED You Can Blow Out and code.
Step 1: Supplies.
supplies you will need
1: Arduino uno
2: LED
3: Straw
4: USB type A cable
5: Resistor
6: Breakaway header pins
7: Screwdriver.
Step 2: LED and Resistor
solder it just like the images above.
Break of 1 header pin and brake of another 2 header pins.
Solder the black wire to the first header pin.
Solder the other end of the black wire to the negative side of LED.
Now solder the resistor to the right side of your two header pins
solder the red wire to the left side of your two header pins join the resistor to the red wire.
For further description
Step 3: Connect Your LED to ARDUINO
Connect your LED Arduino just like the image above.
Connect negative side of LED to Arduino pin GND.
Connect positive side of LED to pin A0.
Connect resistor header pin to A1 pin of your Arduino.
Step 4: Building the Candle
Cut the straw the length you want your birthday cake candle to be.
Now with a screwdriver push the LED threw the bottom side of the
straw so that it is 95% of the LED is sticking out of the straw.
Now push the straw and LED threw the bottom side of your cake so that
your wires stick out the bottom of your cake and lead to your Arduino.
    • Warm and Fuzzy Contest
    • Faux-Real Contest
      Faux-Real Contest
    • Sweet Treats Challenge
