LED Dimmer Circuit | 555 Timer | Electronics Project
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today in this video tutorial i am going to show you Step By Step
How to make led dimmer circuit using 555 timer ic
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Code
• Datasheet
• Pin Configuration Etc
AT ► https://circuit-diy.com/led-dimmer-circuit-555-timer-electronics-project/
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Material
❖ Hardware Required ❖
► 555 Timer IC
► 9V Battery with Clip
► Breadboard
► Jumper Wires
► 1k ohm resistor
► 220 ohm resistor
► 10k variable resistor
► 100nf ceramic capacitor x2
► LED
► 1N4148 diode x2
❖ Circuit Diagram ❖
Link ► https://www.file-upload.com/zfk6f5eff771
Step 2: Useful Steps
❖ Steps ❖
STEP # 1 ( Connect IC )
► Connect 555 timer IC on bread board
STEP # 2 ( Make power connections )
► Pin 8 of 555 Timer – To VCC of Battery
► Pin 1 of 555 Timer - To GND of Battery
STEP # 3 ( Connect Resistor )
► Connect wire BTW pin 2 and pin 6
► Connect pin 4 to VCC
STEP # 4 ( Connect Capacitor )
► Connect 100nf cermecic capacitor on pin 5
► Connect 100nf ceremeic capacitor on pin 6
STEP # 5 ( Connect resistor #1 )
► Connect 1k ohm resistor pin 7
STEP # 6 ( Connect Variable resistor )
► Connect 10k ohm variable resistor on board
STEP # 7 ( Connect didodes and make connections )
► Connect diode BTW right leg of variable resistor to pin 7
► Connect diode BTW left leg of variable resistor to pin 7
► Connect wire BTW middle leg of variable resistor to pin 6
STEP # 8 ( Connect resistor and LED )
► Connect 220 ohm resistor on pin 3
► Connect LED on pin 3
STEP # 9 ( Testing )
    • Tape Contest
      Tape Contest
    • Pocket Sized Contest
    • Organization Contest
