LED Growing
Introduction: LED Growing
This project is about using Led to helps plants grow.
Red LED can help plant's Promote lateral branching and tillering
Green LED can help plants Strengthen growth
Blue LED can help plant Shorten internodes, reduce leaf area, reduce relative growth rate, and increase nitrogen ratio
And this project gather 3 LED to let the plants growing work getting easier.
Which part of the plant that you are not satisfaction, you can use the different LED to change it.
Teacher Notes
Step 1: Things to Use
Prepare cardboard x 6
Red Led x 3, Green LED x 3, Blue LED x 3
Cellophane x 1
Breadboard x 1
wire x 21
Resistance x 9
Botton x 3
Step 2: How It Works?
Three Button
when to push, one of them, the Red LED will shine
one of them, the Green LED will shine
one of them, the Blue LED will shine
Step 3: Code
void setup(){ // put your setup code here, to run once:
pinMode( 4 , INPUT); // sets the digital pin as input pinMode( 11 , OUTPUT); // sets the digital pin as output pinMode( 12 , OUTPUT); // sets the digital pin as output pinMode( 13 , OUTPUT); // sets the digital pin as output pinMode( 3 , INPUT); // sets the digital pin as input pinMode( 8 , OUTPUT); // sets the digital pin as output pinMode( 9 , OUTPUT); // sets the digital pin as output pinMode( 10 , OUTPUT); // sets the digital pin as output pinMode( 2 , INPUT); // sets the digital pin as input pinMode( 5 , OUTPUT); // sets the digital pin as output pinMode( 6 , OUTPUT); // sets the digital pin as output pinMode( 7 , OUTPUT); // sets the digital pin as output }
void loop(){ // put your main code here, to run repeatedly: if (digitalRead( 4 )) { digitalWrite( 11 , HIGH ); // sets the digital pin on/off digitalWrite( 12 , HIGH ); // sets the digital pin on/off digitalWrite( 13 , HIGH ); // sets the digital pin on/off delay( 5000 ); // waits a few milliseconds digitalWrite( 12 , LOW ); // sets the digital pin on/off digitalWrite( 13 , LOW ); // sets the digital pin on/off digitalWrite( 11 , LOW ); // sets the digital pin on/off } if (digitalRead( 3 )) { digitalWrite( 8 , HIGH ); // sets the digital pin on/off digitalWrite( 9 , HIGH ); // sets the digital pin on/off digitalWrite( 10 , HIGH ); // sets the digital pin on/off delay( 5000 ); // waits a few milliseconds digitalWrite( 8 , LOW ); // sets the digital pin on/off digitalWrite( 9 , LOW ); // sets the digital pin on/off digitalWrite( 10 , LOW ); // sets the digital pin on/off } if (digitalRead( 2 )) { digitalWrite( 5 , HIGH ); // sets the digital pin on/off digitalWrite( 6 , HIGH ); // sets the digital pin on/off digitalWrite( 7 , HIGH ); // sets the digital pin on/off delay( 5000 ); // waits a few milliseconds digitalWrite( 5 , LOW ); // sets the digital pin on/off digitalWrite( 6 , LOW ); // sets the digital pin on/off digitalWrite( 7 , LOW ); // sets the digital pin on/off } }
(You needs to change the delay(5000) to how long you needs, or wants the LED shine )
Step 4: How to Make the Look?
Cut the cardboard into 3 different types
Cut down three hole on the two side of the cardboard, to let the button go through
cut a little hole that can let the Transmission line through
use Hot melt gun to stick them all.
If you want, you can stick the Cellophane on the cardboard, that can let you see the inside.
Step 5: Finish All
Stick the Arduino on the top of the cardboard
fixed the button on the button hole
At last check if it works!
Be the First to Share
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
