LED Strip Amazing Effect
About: Share diy projects to those who have the same hobby with me
Hii friend,
We want good effects of LED strip.LED strip decor our room and when it give effects then room looks amazing.If your LED strip glow simple, then this blog is very special for you because in this blog you will learn how can we make amazing effect light of LED strip without wasting money.
In this project I will use only one LED and this project will be done.This is very cheapest project.
Let's get stated,
Teacher Notes
Step 1: Take Parts As Shown Below
For making amazing effects of LED strip project we need -
(1.) RGB LED -3V x1
(2.) LED strip
(3.) Adapter - 12V (DC)
Adapter will give 12V DC power supply to the circuit that which circuit will work.
Step 2: Connect RGB LED to LED Strip
Firstly we have to connect RGB LED to LED strip.
LED strip effect will be according to RGB LED . As we know that RGB/multi-color LED glowing with red , blue and green with effect. So when we will connect this LED in series then LED strip will also glow like as multi-color LED.
Connect +ve wire of LED strip to -ve wire of multi-color LED as solder in the picture.
Step 3: Now Connect Power Supply Wire
Next we have to connect 12V power supply wire to the circuit.
Connect +ve wire of power supply to +ve leg of LED and
-ve wire of power supply to -ve wire of LED strip as solder in picture.
Step 4: LED Strip Effects
As you can see in picture the effects of LED strip.
LED strip will blink according to multi-color LED.
If you want to make more electronic projects then follow utsource now.
LED strip give really amazing effects so try to make this project.
Thank you
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
