Introduction: LED TV Light Mod
The only catch is that your TV must have a USB port of some kind on it. Samsung TV's have a USB port to plug in flash drives for viewing pictures or listening to music. Most other brands have something similar.
Step 1: What You Will Need
10 blue LEDs
25ohm 1 Watt Resistor
A spare USB Cable
Hook up wire
PCB board
Heat Shrink Tubing
Solder
Soldering Iron
Torch or Lighter
Double Sided Foam Tape
Wire cutters
Access to a Ban Saw or Dremel - Eye Goggles too!
I get my LEDs form here:
http://www.ledshoppe.com/led5mm.htm
Step 2: Solder Your LEDS
Depending on your TV or monitor's size and space available you may want to arrange them in your own way. I am choosing to have two rows or 5 LEDs for the top and bottom of my TV. But you can also do 1 row of 10 LEDs.
Solder them all in parallel. All the Positive connections (longer lead) are soldered to together and all Negative connections (shorter lead) are soldered together.
Be careful not to short out your connections.
Step 3: Solder on the Hook Up Wire
Solder your positive lead and negaitve leads from your hook up cable to your LEDs.
Put some Heat Shrink wrap on the wire before you solder it in place. Depending on how thick your LED bars will be when you cut them out will determine what size heat shrink you will need. I'm using 1/4in.
Cut them out carefully with a ban saw or Dremel. Wear Eye Protection!!!
Slide the Heat Shrink tubing over the ends and heat them with your torch to secure them in place.
Step 4: Prepair the USB Cable
Grab your cable and cut it to about 8 inches.
There are four wires coming out of the cable and a ground coax. The only two we are going to need is the red and black wires. Cover the green and white wires with heat shrink so they don't short.
RED is Positive
BLACK is Negative
Connect the 25 ohm resistor to the positive red wire and then connect the other side to the positive of your LED's. The resistor should be in series with your LEDs.
Note in the picture I didn't have a 1 watt 25 ohm resistor so I made one out of 4 1/4 watt 100ohm resistors in parallel.
Cover everything with 1/4 in heat shrink.
Step 5: Test for Shorts
Since this is going to be plugged into a USB port you want to make sure everything is working. You do not want to short out your USB device because it could damage your TV or computer!
To test for shorts connect 2 AA (3v) to the PCB (bypass the resistor) to see if they light okay. If they don't light check your connections for shorts. If just one or more does not light make sure the polarity is correct. If everything seem good, you're done.
Step 6: Mount Them to Your TV
Using double sided tape you can mount them to the back of your TV or Monitor. Plug in the USB port on your TV or Computer and turn it on.
They should turn on and off with the device.
Congratz your TV is killer now!
