LED Table Lamp Using PVC
Introduction: LED Table Lamp Using PVC
About: I like Building Electronics Projects , circuits
Today I am going to Build Simple LED Table Lamp using PVC.do it yourself project .LED Table lighting may be used for activities which need high focus – reading, writing, craft work, working, using a computer, putting on makeup or even shaving.Your regular light in the house is not designed to be suitable for all activities.it will work in 230v AC
Teacher Notes
Step 1: Things We Need to Build LED Table Lamp Using PVC
1.Acrylic Sheet Clear white - 15x20cm - 1
2.Acrylic sheet Round - 60mm dia
3.Barrel Jack 230v AC - 1
4.PVC Pipe - 3/4 - 45cm Length
5.PVC coupling - 2.1/2 - 1
6.PVC coupling - 3/4 - 1
7.PVC Reducer - 64x40mm-1
8.PVC Reducer - 3/4 - 1
9.Flexible PVC - 10cm -1
10.Wire Mulistand - 1 meter Red & Black
11.Power cord 230v AC
12. Heat Sleeve - 10cm
13.LED Module with 230v Controller Board -32 SMD LED
14.230v Male connector
15.Fevi glue - 2
Step 2: Soldering & Drilling
1. Take the Multi Strand wire and solder it into the Barrel Jack
2. Take the PVC Coupling and put a hole of 12mm dia
3.Now insert the barrel jack into the coupling as shown in image
Step 3: Casing Assembling 1
1.Insert the wire through coupling
2.Insert the wire through Acrylic sheet Round into the coupling
3.Insert the wire through 3/4 Reducer and screw it to the Round Acrylic sheet
4.Now screw the PVC Reducer and Coupling
5.using glue stick the Acrylic Round into the Coupling
6.Now Insert the wire through PVC pipe 3/4 As shown in image
7.Now insert the PVC pipe into the Reducer
Step 4: Casing Assembling 2
1.Now Insert wire through the Flexible PVC
2.Insert the Wire into the LED head (PVC Reducer )
3.Take the LED module and connect the Red to Phase and Black wire to Neutral and solder it insulate with heat sleeve properly
4.Stick the LED panel into the PVC coupling and fix it.
5.Now finally Take the Table lamp base Acrylic sheet stick it to Table lamp base coupling
Step 5: Output
Now connect the 230v Ac Adapter into Table Lamp On Switch On the supply.
Enjoy Lighting.This LED based Table lamp uses ultra-bright white LEDs to provide sufficient light for reading
Step 6: Troubleshooting
Troubleshooting
Check the Power Supply
While checking the wire connection check the switch is in OFF state
Check the Soldering Connections
Check the Barrel Jack adapter is any soldering removed
Plastics Contest
Plastics Contest
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    7 Discussions
    sajece
    sajece
    1 year ago
    wow great work man very simple and creative work
    SAJIBENU
    SAJIBENU
    Reply 1 year ago
    thanks jessy
    SAJIBENU
    SAJIBENU
    Reply 1 year ago
    pls vote my project
    Jessy b
    Jessy b
    1 year ago
    It's simple and cool idea. Well done.
    SAJINVillukuri
    SAJINVillukuri
    1 year ago
    oh this is awesome project i love it i am going to try this project myself
    SAJIBENU
    SAJIBENU
    Tip 1 year ago
    LED Table Lamp Pics
