Laser Cut Box
Introduction: Laser Cut Box
This is based on KevinKarney's tutorial.
Supplies:
.3mm plywood
Adobe Illustrator
Step 1: Follow Kevin's Instructions
Follow the instructions of this tutorial.
Some additional tips from me:
- Kerf (if you didn't already know) is the width of the laser, which can skew the size. Kevin's program helpfully includes a kerf finder which is worth doing if you have excess material.
- There are some setting that can make the box customizable. For me, I choose to take off the magnetic latch and have only 4 hinges instead of the 6.
Different things I have changed for each iteration:
Iteration 1: width of wood: 3mm
Iteration 2: kerf: 0 ; width of wood: 3.5mm
Iteration 3: kerf: 0; width of wood: 3mm
Step 2: (Optional) Using Adobe Illustrator to Change Positioning
Using Adobe Illustrator, the layout of the box can be changed to better fit on the material. For me, my board was 30-by-30 so I rotated pieces and placed them so that they would fit. I added additional hinges to my layout in case I broke or lost some so that I have replacements.
Step 3: Cut It!
Use a laser cutter to cut it! For me, I choose a material of General Medium Wood with a thickness of 3.5mm. This depending on the cleanliness of the laser and other factors should give a pretty nice cut.
Times it took for each iteration to cut:
Iteration 1: 2 passes around 5 minutes each
Iteration 2: 1 pass around 5 minutes
Iteration 3: 3 passes around 5 minutes each
Step 4: Assemble It!
For boxes that are too loose to be tight fit, I recommend using wood glue to put it together. A little glue, on the edges give a nice tight bond. However, my goal was to make it press-fit which may have been possible with the last iteration.
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
