Laser Cut Eye of Agamotto
12,151
106
13
Introduction: Laser Cut Eye of Agamotto
About: I am a woodshop/maker teacher. I have been woodworking since I was 9. I like to make things that are out of the ordinary to push myself and continue to learn and grow. I try to challenge my students to do th...
I was feeling a little strange one day. Felt the need to turn back time so I got to tinkering on this project.
I made this to show my students what you can do with a laser cutter when you stack layers to make 3D out of 2D layers. Don't worry I have some more entry-level examples too. I used Fusion 360, Adobe Illustrator and a Glowforge laser cutter. The wood used was 3/16" plywood from the hardware store. I also used some green wood dye.
**I am now thinking of improving on this with a green LED in the center to make it glow as you turn the face to turn it on. This was a good starting point example for my students.
Teacher Notes
Step 1: Design in Fusion 360
My design was made in F360. The video does a full walkthrough of the process.
  • Import an image of the Eye of Agamoto
  • Think of each feature on the eye to be a separate layer.
    • Each layer is a different sketch.
  • Make sure all your cut lines are separate vectors (lines) from the score lines. This meant using the trim tool for my design.
  • Export the sketches as DXF files.
Here is the link to my Fusion file
Step 2: Illustrator to Convert Files to SVG
Our laser needs SVG files. Illustrator was used for this. I have used Inkscape in the past but it does not like the splines that F360 makes.
In Illustrator I also recolored the lines that I wanted to be score lines vs. cut lines. In my files, I made them blue and black. The colors of blue are slightly off from each other so when lasering they show as three colors. Be aware of this and make sure you select the correct things to be cuts and scores. I was too lazy to fix it.
Step 3: Cut!
Import the files to your laser and cut them out. I dyed the green piece before cutting it out.
*Next time some of the connections should be thicker. You see that some of it burned a little too much in the detailed layer 4 piece.
Step 4: Glue Up
I was in a rush so I used super glue but normal wood glue would work too. Make sure you clamp it up.
Step 5: Finishing
I sprayed two coats of clear acrylic on to seal it from getting dirty and to keep the burnt smell down. I then sewed on a leather strap with just a few stitches. Nothing fancy
Now it is time for some wizardry time bending. You can see I have been practicing.
Fandom Contest
Runner Up in the
Fandom Contest
3 People Made This Project!
  • Sculpting Challenge
    Sculpting Challenge
  • Tiny Speed Challenge
  • Heart Contest
    Heart Contest
13 Discussions
eddbuzz
eddbuzz
5 weeks ago
amazing work, thank you
itallo2701
itallo2701
3 months ago
thanks for the file, I just slowed down a bit because it was too big kkkkk
PS: he is not glued or anything just finished the cut and took the picture
offseidjr
offseidjr
8 months ago
I love that movie!!!
triangular deco
triangular deco
10 months ago
this would be great with Spinning circles
terrefirma
terrefirma
10 months ago
Funny when you say "I was in a hurry" when this whole thing seems so time intensive! Then you film and explain it all! Did you just do it again when filming? Used notes?
Where do you teach? I'd love to hear your journey..
gasserwoodshop
gasserwoodshop
Reply 10 months ago
Hurry as in I was excited to get it done before my students showed up so I could show them :)
Fusion 360 lets you "go back in time" to see the steps you have done. Appropriate for this project.
I teach in the San Fransisco area.
LuisM379
LuisM379
10 months ago
Thanks for the files. Condensed files down to three layers, with middle layer holding an acrylic piece and a hole in the last one for light to shine through.
fredyf57
fredyf57
10 months ago
Very Cool and great instructions. Thank you.
barnabasjohnthomas
barnabasjohnthomas
10 months ago
Dude, this is some real cool stuff. You're the man :D
MaraCreates
MaraCreates
10 months ago
You are very talented, it is very beautiful!
lteget72292
lteget72292
10 months ago
You are Dr. Strange
