Laser Cut or CNC Milled Corner Lamp
Introduction: Laser Cut or CNC Milled Corner Lamp
About: Love to make or innovate. Macgyverism at work. Fun and Joy makes toughest projects worth while. Keeping it Real.
A simple DIY corner lamp to get familiar with Laser cutting or CNC milling methods and while at it manufacture a corner lamp for your room.
Hope you guys have fun making this as I did.
Teacher Notes
Step 1: Cutting 3mm Acrylic Sheet
Using the provided layout above cut the acrylic sheet in its form using a Laser cutter (Thicker or thinner sheet will have fixing issues)
ALTERNATIVE
CNC milling can also be used to cut a plywood of the same size. (Thicker or thinner sheet will have fixing issues)
Step 2: Fixing the Lamp
Put the cut pieces into the 2 discs and form a lamp as shown. Preferably use Chloroform for bonding.
If the cut pieces are formed from Plywood then wood epoxy should be used.
A standard lamp fixture or bulb holder from your local hardware store would suffice for housing the bulb.
Step 3: Decorating It With Nylon Rope
Use your choice of colored nylon rope and wrapped it on the edges that are already cut in the design.
Voila a beautiful made corner lamp.
Epilog X Contest
Epilog X Contest
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    2 Discussions
    audreyobscura
    audreyobscura
    1 year ago
    This is a cute string lamp design!
    Alpha_Z_Prime
    Alpha_Z_Prime
    Reply 1 year ago
    Thanks!! Glad that you like it!
