Lathe Tool Organizer
Introduction: Lathe Tool Organizer
About: ryan pouin
In this intractable I will show you how to make a lathe tool organizer, you will need a sheet of plywood 1/2 inch, pvc 7 inch at 45 degree angles, and scrap wood depending on the number of things you need to organize.
Step 1:
Cut PVC pipe to the desired length i cut 7 inch pieces, then sand the ends if needed. I cut them at a 45 degree angle.
Step 2:
Screw them down or glue them down to some plywood 1/2 inch, I would suggest screws 1/2 inch.
Step 3:
I used a drill press to make holes in everything before i started attaching things.
Step 4:
You can take any type of scrap wood to use to hold the tools. i just drilled holes through some wood and organized it to fit.
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Looks great! Love the use of PVC pipe :)
