Launch It: the Improved CD Hovercraft.
43,839
36
35
About: The answer is lasers, now, what was the question? If you need help, feel free to contact me. Find me on Reddit, Tumblr and Twitter as @KitemanX
The CD hovercraft is a tried-and-tested Make, but technological improvements have tended to be in the method of connecting the balloon to the CD. I have attempted to apply some of Sir Christopher Cockerell's original developmental research to this old favourite.
Step 1: Materials and Tools
In addition to the basic materials (an old CD, a balloon and a plastic bottle cap and hot glue), you will need a sheet of paper or light card, a thin sheet of expanded polystyrene, ordinaryglue and a sharp knife.
The type of glue is not vitally important, since it will not be under any strain greater than the weight of the polystyrene and paper. If you use a water-based glue, though, try and be very sparing with it, as excess water will make the paper "cockle" and cut the vehicle's efficiency.
Step 2: What Are the Improvements?
Hovercraft gain lift from pressure-drops. More rapid changes in pressure and downward air-velocity give rise to greater lift.
Early attempts at a hovercraft simply blew air down an open shaft towards the ground. However, when the bulk of the shaft was closed off, and the air-flow restricted to the edges of the craft, the increase in lift was startling.
In the traditional CD hovercraft, the drop in pressure is gradual, spread over the whole surface of the CD. We are going to use the polystyrene and paper to create channels that will restrict the airflow so that the pressure-drop occurs more rapidly near the edge of the disc.
Step 3: Restricting the Flow.
The air is restricted by using channels cut in a layer of polystyrene, capped by a layer of paper.
Using the attached templates, cut pieces from the polystyrene and the paper. If you are doing it by eye, remember that the CD has a diameter of 12cm.
It is easier to glue the polystyrene to the paper, and then both to the CD. Use the "normal" glue to do this, being careful not to clean off any "ooze" before it dries: blobs of glue on the bottom of the hovercraft will catch on the surface below the craft and slow it down or even stop it completely.
Step 4: The Traditional Bit
Drill a hole in the middle of the bottle cap, as large as the hole in the CD.
Hot-glue the cap to the CD, upside down. As you press the cap in place, gently twist it to ensure the glue forms an air-tight seal. You must be very careful to avoid glue oozing through the hole in the CD, as it will block the channels you have just made.
When all the gluing you did has dried and/or cooled, blow up your balloon and twist the neck to keep the air in.
Stretch the neck over the cap, place the hovercraft on a smooth surface and let the neck untwist. Air will rush down the channels, under the craft and lift it on a cushion of air. The slightest nudge should send the hovercraft scudding away.
Step 5: Launch It!
Time to be honest - things did not go as well as expected.
The hovercraft worked, but the large hole in the cap meant that it only ran for a couple of seconds.
Restricting the air-flow seemed to cure this, but I left things a bit late to finish this Instructable, and did not wait until the glue dried before testing. (Bad Kiteman, naughty Kiteman!)
This meant that the glue oozed through the paper and stuck to the mat while I was holding the hovercraft still.
Have a look at the video to see the results so far, but the deadline is too close to be able to try it with a dry, non-adhesive base.
Step 6: Lacking Motivation?
If your smooth surface is also level, the hovercraft will not move unless you nudge it.
You may want to add one or two narrow extra channels through the outer ring of polystyrene to the edge of the disc.
The portion of air that leaks through these channels should provide enough thrust to propel the hovercraft across the desk.
Build two or more CD Hovercraft with thrust channels, and you can race them across the kitchen floor - the loser washes up!
  • Holiday Decor
    Holiday Decor
  • Toys Contest
    Toys Contest
  • Baking Challenge
    Baking Challenge
35 Discussions
ilpug
7 years ago on Introduction
These are really fun to make. I recognize that set of craft knives, i bought mine for 99c at a discount store and most of them broke in a week. How did yours hold up?
kiteguy
7 years ago on Step 3
Hummmm,
Quote: "being careful not to clean off any "ooze" before it dries: "
Perhaps this is one reason it would not "fly" as wanted.
Wyle_E
10 years ago on Introduction
If you have a source of dry ice, a small plastic bottle of dry ice chips would last longer than the air in a balloon. The original version of this gadget is the "dry-ice puck" that's been used in physics classes for almost a century. It has a thick, polished steel puck instead of the CD, and a copper ball (remember copper toilet-tank floats?) to hold the dry ice. With that much mass, it would glide *slowly* for several yards without visibly slowing. One of these days I may dust off my old Unimat lathe and make one.
KitemanWyle_E
That is true, of course, but most readers won't have access to lumps of dry ice.
Kryptonite
10 years ago on Step 5
I've tried this the "Original" way, and I think it worked better than yours, any ideas why? I thought that yours would go better, oh well, better luck next time.
astro boy
replace the cd with another piazza base more power or smaller hole longer run
Kaiven
11 years ago on Introduction
do you kkow where polysterine can be found in a house? where i live, we don't have that kind of pizza stuff. Alos, is there anything else i can use? thanks
Wyle_Eshadowgravity
Yes. It's clear that you want polystyrene foam, aka styrofoam, and not solid polystyrene. Open-cell foam (the original Styrofoam) won't work here, because it won't hold air. Closed-cell foam, used in disposable cups and plates, is what works.
KitemanKaiven
Reply 11 years ago on Introduction
Ceiling tiles? DIY stores sometimes sell thin sheets of expanded polystyrene as insulation (maybe to go behind radiators), craft / modelling stores will sell it as a modelling material, or be able to advise on other alternatives.
KaivenKiteman
oh! i found something! maybe a styrofoam meat tray. Mine had chicken :)
