Launch It: the Zero-Wind Indoor Pizza Kite
10,561
12
24
Introduction: Launch It: the Zero-Wind Indoor Pizza Kite
About: Find me on TikTok, Reddit, Tumblr and Twitter as @KitemanX.
You're bored. You're desperate to fly a kite, but it's raining.
Have a pizza while you read the rest of these instructions.
Step 1: Materials and Tools.
You will need:
The polystyrene disc from under a store-bought pizza.
Sharp knife ("X-acto" or similar. The ones I use come under the heading of "similar" - they cost me £1.99 ($3-$4) from my local Morrisons Supermarket).
Scissors.
Sticky tape. You may need to use duct tape: if your pizza base is greasy, normal tape sometimes won't stick.
Sewing thread.
Wool.
Optional: paper template. I needed to use the template because my pizza base was black, and so is my pen. Some bases are white, and you can draw your pattern directly onto them.
Step 2: The Parts.
The shape we are going to do is my own variation on a traditional diamond kite. My boys call it a fish kite. You can experiment with shapes, but remember that,as a rule, they need to be symmetrical.
The template:
Cut a square, and draw a line corner-to-corner. Mark a point one quarter of the way along the diagonal. Draw lines to the other two corners and cut along them. You will have a wide kite-shape and a chevron.
Stick the chevron back on the square, but at the opposite corner to the one you cut off. The diagonal line on the chevron should line up with the diagonal line on the larger part. Check the photos to see what I mean.
Draw the shape onto your pizza-disc (most of the flat pizza bases seem to have a pattern of square dimples, which makes life easier - you can count along them and use them for guide-lines if you want to draw your shape directly onto your base) and cut it out with the sharp knife.
Step 3: Putting the Kite Together.
Cut eight pieces of wool about 60cm (two feet) long and knot them into two bunches of four.
Tape each bunch to one of the points of the "fish tail" - put the end of the wool next to the point of the kite, sandwich them in the tape and trim off the excess.
Find the point which used to be the centre of the square, and move a centimetre or two along the centre line of the kite towards the tail. Pierce through and thread the sewing thread through. Tie a large knot at the back of the kite and anchor it with a small piece of tape.
You are now ready for a test flight.
Step 4: Flying the Kite.
Normally, kites fly by deflecting down a mass of moving air. By Newton Third Law, deflecting the mass of air down deflect the mass of the kite up. This NASA image shows the idea.
Unfortunately, sometimes the air doesn't move. That's when this kite comes in - it is light enough that it takes very little motion to give it lift.
You can take this kite for a walk, or just circle on the spot to get it air-borne. If you're going to stand still, though, I would fasten a short flying line to a length of bamboo or cane - wave it slowly around to fly your creation. A narrow figure-eight motion helps prevent tangles between tail and flying line.
If the kite is unstable, there are a few things you can do. Try them in this order, as the last one is hardest to undo:
1. Slow down - don't run around the room, walk.
2. Lengthen the flying line by a metre or two to let the kite fly away from the turbulence generated by your body.
3. Lengthen the tails by about 15cm (six inches).
4. Bend the kite - using a ruler and the blunt side of a blade, score down the centreline of the back of the kite, then gently crease along the score so that both side move up slightly. If you make a mess of this, you will have to start again from scratch.
Although this is officially an indoor kite, it will fly outside in light, steady winds, or it can be taken for a walk along the beach...
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    24 Discussions
    ilpug
    ilpug
    8 years ago on Introduction
    I have never seen polystyrene used to holdpizza, but i think here in the US there are picnic plates made of it that would work the same.
    mibzman
    mibzman
    9 years ago on Step 4
    that's not a real kite! ur just taking a pice of card board, tying a string to it, and swinging it around above ur head.
    Kiteman
    Kiteman
    Reply 9 years ago on Step 4
    Please, read the instructable.
    It is polystyrene (very light, yet rigid), and I did not "just tie a piece of string to it", I attached a thread to a designed location.  Watch the video - the kite flies above the level of the anchor. That is, it exhibits lift, known colloquially as "it flies".
    I could have flown the kite much more successfully outdoors, but I wanted to be a little different (only a little, though, as this is how microkite builders fly their creations).
    Grey_Wolfe
    Grey_Wolfe
    10 years ago on Step 4
    Nice little toy.
    With the intro picture I thought the kite was gonna look like a slice of pizza though. lol
    rc jedi
    rc jedi
    Reply 11 years ago on Introduction
    I do r/c planes, but used to fly control line. After a few dozen flights around and around, I got kinda' used to it. But never really immune. Just not sick. That kite is really flying. good material, tough enough for kids it looks like to me.
    Kiteman
    Kiteman
    How do think I felt making it? That wasn't one take, I spent quite some time spinning on the spot, and had to have a nice sit down afterwards...
    fatboy106
    fatboy106
    11 years ago on Step 1
    morrisons have just recently taken over our co op ,and things have never been better!
    safety dance
    safety dance
    12 years ago on Introduction
    LOL, u need 2 make 1 with a quick release mechanism so that it can launch n2 walls! =P
    westfw
    westfw
    What brand of pizza? Around here, the last "store bought" pizzas I've bought have had cardboard holders... A meat tray might work?
    Kiteman
    Kiteman
    Reply 12 years ago on Introduction
    We generally buy pizzas from Morrisons or Tesco (UK supermarkets).
    Meat trays would certainly work, as would some disposable picnic plates - all it really needs is a flat sheet of expanded polystyrene, or any other similarly light and rigid material.
    You could make it to include the curves at the edges, but you'd have to be very careful to make the curves absolutely symmetrical,
    crapflinger
    crapflinger
    "Cut eight pieces of wool about 60cm (two feet) long and knot them into two bunches of eight." did you mean two bunches of 4? nifty kite-age...no numbered offspring in this one though hehe
    Kiteman
    Kiteman
    Oops! (Quickly runs off to edit)
    Patrick Pending
    Nice Instructable Kiteman. Would it fly if you tethered it to a desk fan? I'm thinking the airflow might be to turbulent. Cheers, Pat. Pending
    Kiteman
    Kiteman
    Yes, too. Very too. Maybe from an antennae on the back of a bicycle?
    Patrick Pending
    Patrick Pending
    You could use slightly curved piano wire to attach miniature kites with tails to a desk fan, It would give the illusion that they are flying. A sort of executive toy for a Kiteman.
    Kiteman
    Kiteman
    I have a desk-toy kite that's made of thin glass on piano-style wire - every nudge of the desk and the kite twitches.
    lemonie
    lemonie
    Nice parquet floor! L (very heavily-buffed, be great for skids)
