Learn From Beebeecraft How to Make a Pair of Pink and White Seed Bead Hoop Earrings
195
Introduction: Learn From Beebeecraft How to Make a Pair of Pink and White Seed Bead Hoop Earrings
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Do you love DIY hoop earrings? This Beebeecraft beaded hoop earring tutorial aims at introducing you this piece of pink and white seed beads jewelry; I believe you will be attracted by it.
Beading is the main technique used in making this seed beaded hoop earring. If you’re a starter at making jewelry, don’t worry, free details patterns on making beaded earrings are provided. Follow me to see the tutorials details.
Teacher Notes
Step 1: Materials Needed in Making Beaded Hoop Earrings:
4mm pink Glass Seed Beads
4mm white Glass Seed Beads
1mm Silver Copper Jewelry Wire
Silver color headpins
Silver earring hooks
4-10mm Brass jump rings
Step 2: Make the Hoop for the Beaded Hoop Earrings
1st, thread a white seed bead, a pink seed bead, and then continue to slide to a headpin (as the picture shown);
2nd, make a hoop on the other end of the silver headpin, and make 4 pairs of shorter bead patterns like the picture;
3rd, cut off about 12cm copper wire, curve the wire to form an open circle, and make a loop of one end of the copper wire;
4th, slide the pink and white seed beads separately like the picture, add the shortest bead dangle on the outside and almost the middle of the wire, slide one more pink seed bead, add longer bead pattern.
Step 3: Finish Pink and White Beaded Hoop Earrings
1st, continue to add seed beads and beads dangle patterns like the picture until beads full of the wire, and make a loop at the other end of the wire;
2nd, add a jump ring to connect the 2 loops of the hoop wire, and then attach an earring hook to the jumpring.
Step 4: Here Is the Final Look of the Pink and White Seed Bead Hoop Earrings.
So far, this seed beaded tutorial has been finished! Have you learnt how to make beaded tassel earrings? If yes, don’t hesitate to make such seed beaded earrings, and u can change the colors as you like. You can find all jewelry craft supplies you need for this on Beebeecraft.
Be the First to Share
    • Fandom Contest
      Fandom Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Backyard Contest
      Backyard Contest
