Let's Make a Kunai Knife
1,152
4
Introduction: Let's Make a Kunai Knife
About: a teenager eagerly doing all fun DIY projects that I can do now because now I have TIME, FREEDOM, and couple of bucks when I need them. will appreciate suggestions from experts when they think I need them.
Hi guys here's a tutorial of casting a Kunai Knife.
Say "Hi: on social Media
Facebook: https://web.facebook.com/diyer.diyer.372
leave a comment on what video should I make next.
Some of my other Videos:
Warning:I am NOT responsible for what ever you do with the knife.This information is only for Educational Purposes!
Step 1: Making the Styrofoam Kunai
Note:Use a slightly thinner sheet to make the Kunai or you'll end up with a very fat kunai that won't penetrate anything.Also this Project involves a lot of grinding as the Kunai made by this method is rough initially.
Draw a Kunai on a Styrofoam and then cut it out using a cutter.Make the edges of the Kunai using the cutter.
Step 2: Making the Cast
Burry the Kunai in ordinary sand and use a sprinkler to settle the sand and then make a hole as an inlet for the molten Aluminium.
Step 3: Casting and Grinding the Kunai
Pour the Aluminium into the cast and wait for about 10 minutes before pulling out the Kunai using a pair of pliers.
Step 4: Making the Hole for Holding
The hole for holding the Kunia is important because it lets you swing it in your hands and do a lot of other cool styles:) :P
Use a small drill bit to make a small hole at the end of the Handle and then use a broader drill bit to make the hole bigger. Utilise a metal file to make the hole even bigger and to file down sharp edges which can cause cuts on your hands.Use a grinder with polishing disc to polish the blade.
Step 5: Now You Are a NInja.
Like the Shuriken?
Check out the video on My YouTube Channel.
Practice throwing the knife at a wooden board. After sometime you'll get hang of it and you'll be able to hit the target quite often.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    3 Discussions
    MantisA
    MantisA
    Tip 1 year ago on Introduction
    instead of using one hole to pour themolten mterial into, create an inlet and outlet port(tall cans work fine). thhis will cause your mold to burn and give the metal room in the sand. the preassure releae will cause your cast to be identical to the mockup
    Eunix
    Eunix
    2 years ago
    Nice project!
    diyer2112
    diyer2112
    Reply 2 years ago
    Thanks.
