Levitating Lemur
3,760
22
8
Introduction: Levitating Lemur
About: I'm an IT professional, maker, hobbyist, really like to make different things with kids and play/test with them in a spare time.
Hello everyone, here is an instructable how to make "levitating effect" for figure on the pencil top for kids. It' not proper levitation, because one end is held by fishing line. In this instructable I used thick green coloured fishing line to make it more visible to illustrate the process. For the real world project could be taken transparent with 0.1- 0.15mm thick. Transparent one is not visible from the distance in 0.5 m in daylight, so it look like plastic figure is levitating.
If you interested in how to do this, let's continue.
Supplies:
• small plastic/rubber figure
• piece of the thin fishing line
• 2 x neodymium magnets I've used cylinder shaped with 5mm in diameter
• tooth pick
• drill with 2 drill bits, one have to be the sane diameter as magnets
• sharp knife
• basic pencil or pen that is suitable for the diameter
• 3D printer
Teacher Notes
Step 1: 3D Models to Print
Here is the models to print in 2 file formats, STL file is ready for the printer slicer, so can be downloaded and printed with no changes.
Model from the solid works, could be adjusted to fit your needs and exported as STL.
Step 2: Preparing the Figure
Using the small drill bit, drill the hole from the bottom, as on the picture #1 for ≈ 2cm in the deep. If you're using rubber figure, take the knife and cut the piece of rubber on from the top of the head. Using the larger drill bit, drill the hole with ≈6 mm in the deep. Push the magnet in the figure's head, apply some glue on magnet and cover it with cut piece of rubber.
Step 3: Finishing the Assembly
tTake a piece of the fishing rod, make a knot on the one end and thread it rethought the hole on the one side of the toy holder, like on the picture. put the second magnet on the toy's head and check the magnet's polarity. Using the same direction of the poles, insert the magnet in the top end. Insert the fishing line in the bottom of the figure, adjust the length and fix the rod by using the toothpick inside the figure. Verify that everything works and figure is not falling out and cut the sticking out piece of the toothpick. Put the whole assembly on the pencil top and it's done!
Magnets Challenge
Second Prize in the
Magnets Challenge
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
    8 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    1 day ago
    I really can't get over how much I love this! So simple and cute and just a fun kids activity :)
    IgorM92
    IgorM92
    Reply 17 hours ago
    Thank you. To be fair, I was playing with this lemur (have to be read as I was testing) for some time until kids took it away.
    mr3d_guy
    mr3d_guy
    5 days ago
    in our complex and troubling world where conflict seem to take over our daily lives, it is great to see inspiring Instructables such as this one to lift our collective spirits!
    IgorM92
    IgorM92
    Reply 5 days ago
    Thank you for the motivating words.
    It's much harder to create simple things and easier to create complex stuff. As for me, simple stuff are making me much happier.
    rsucgang
    rsucgang
    5 days ago
    Very cool project! I will make one!
    IgorM92
    IgorM92
    Reply 5 days ago
    Thank you for the kind words.
    Nice to hear that.
    wannabemadsci
    wannabemadsci
    9 days ago
    I really like the concept and your implementation. With the thin support from below it looks like it is totally floating. Great job!
    IgorM92
    IgorM92
    Reply 8 days ago
    Thank you!
