Library Shelving
2,920
126
9
Introduction: Library Shelving
This 12'x15' room became the nicest room in the house.
Supplies:
  1. 3/4" Furniture grade Birch ply
  2. 1"x? Pre primed pine
  3. crown molding
  4. Base caps
  5. Chop saw
  6. table saw
  7. nail guns
  8. screw gun
  9. Kreg pocket hole j
  10. glue
  11. Paint
Teacher Notes
Step 1: The Room Was a Blank Slate
This is an empty room in our house that was a make shift library formal living room without much storage for books.
Step 2: The Bookcases and Cabinets
Everything was made from 3/4" furniture grade birch plywood and pre-primed pine. The plywood was cut to size and the shelves are inset using a Dado blade set to the right size. This gives the shelves strength for the heavy books that will rest on them. Pine face frames are made with a Kreg pocket hole jig.
Step 3: Installing the Pieces
The bookcases were built in small manageable sections as I was doing this all alone. The sides of the entry are covered with this raised panel detail I made from pine and 3/4" MDF as it routers clean and is smooth for this application. I do NOT recommend using MDF for anything that entails strength!
Step 4: Base Moldings and Details
To tie it all together so it looks seamless I add the base moldings and detail molding.
Step 5: Prime and Paint
Prime and paint everything with a good primer. I use Zinsser Bulls eye water based primer and Benjamin Moore semi gloss Mayonnaise.
Step 6: Add Wainscot to the Walls
I added a simple wainscot to the walls that really ties it all together. The look goes a long way to make this room elegant. Same color as the shelves.
Step 7: Coffered Ceiling
The ceiling was a must to bring it all together. The beams were made from 1"x4" pine in my shop and then simply slide over 2"x4" already attached to the ceiling. Finished the inside with antique tin i simply clear coated and kept the age. Finished with solid crown inside each box.
Step 8: Almost Done
All the painting and detail work is done. Just waiting on the library ladder and some books!
Step 9: Finished Library
There are over 1000 books in here and still a ton more room for more. This has become one of our favorite rooms to sit and relax.
Shelving Contest
This is an entry in the
Shelving Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    9 Discussions
    stllbrown
    stllbrown
    9 days ago
    Beautifully done, and a wonderful instructable.
    heaven69
    heaven69
    12 days ago
    The shelves look amazing. My fiance can do all this, but he just never has time. He's a master mechanic by trade. But does beautiful cabinetry also.
    What state do you live in? You should make yourself available to others to do these shelves. They're so awesome. I would love some for all of my yarn.
    RoccoM
    RoccoM
    Reply 9 days ago
    Thanks, I'm an art teacher by day, wood worker and mechanic on the weekends. I live in NY.
    DrJoMaVa
    DrJoMaVa
    13 days ago
    Looks great! How high is your wainscot? Is it base cap molding inside the panel openings? Thanks!
    MrsWilson46
    MrsWilson46
    Question 13 days ago
    Beautiful! Could you give some guidance on the ladder installation?
    punk chicken
    punk chicken
    13 days ago
    That has always been a part of my (imaginary) dream home.
    jbuckingham68
    jbuckingham68
    13 days ago
    Looks great, nice ladder too!
    Penolopy Bulnick
    Penolopy Bulnick
    15 days ago
    Those shelves are great and that room just turned out fantastic!
