XV-11 Lidar (Raspberry Pi)
About: the Raspberry Pi is Awesome!
How to setup a XV-11 Lidar with the Raspberry Pi.
Use Cases include obstacle avoidance and autonomous navigation for various robotic projects.
Teacher Notes
Step 1: Parts
Gather the required parts:
RPI 3 - https://amzn.to/2VA9pQY
4 Amp Power Adapter - https://amzn.to/2CTptWu
Breadboard - https://amzn.to/2H1ekHs
Breadboard Power Supply - https://amzn.to/2AvjKon
120 pcs jumper cable: https://ebay.to/2VAb9cY
Lidar mount - http://www.thingiverse.com/thing:1707495
Lidar Controller - https://www.getsurreal.com/shop?v=47e5dceea252
XV-11 Lidar - https://ebay.to/2yCIF8G
Step 2: Physical Setup
1. Mount XV-11 to 3D printed mount
2. Route serial data cables and Motor power cables accordingly
3.Plug Male to Male jumper cables to motor power connector and 3.3v breadboard rails
4.Plug serial harness into xv-11 lidar controller 1.2 teensy breakout board
5.Plug mini-usb cable into teensyusb and usb cable into computer
Step 3: Testing
1. Download and install Arduino IDE 1.0.6
2. Download and install teensyarduino
3. Open Arduino IDE, click tools tab and select "teensy 2.0", and "serial" option
4. Your IDE should detect the teensy board, go ahead and click "serial monitor" in tools tab
5. Bottom right select "newline" in drop-down and set baud rate to 115200
6. Send "ShowDist" to display distance data or "ShowRPM" for RPM information
Step 4: Raspberry Pi Setup
1. Unplug usb cable from PC and plug into empty USB-Slot on Raspberry Pi
2. Run "lsusb" in terminal and verify that "Informatic Teensyduino Serial" is present
3. Run "dmesg | grep tty" in terminal and verify you see something similar to "ttyACM0: USB ACM device" and take note of "ttyACM0" (yours may be different)
4. Download lidar script from get surreal page https://www.getsurreal.com/products/xv-lidar-contr...
5. Edit com_port = "/dev/ttyACM0" and set baudrate = 115200
6. Upload script to Raspberry Pi
7. run "pip install pyserial"
8. run "sudo apt-get install visual-python"
Step 5: Run Script
1. Run Lidar Script
2. Right click window to rotate screen to present entire point map
3. Congratulations, your have just implemented a budget lidar system!!
Step 6: Additional Resources
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
    5 Discussions
    Danny Lu
    2 years ago
    Hey, great instructable btw. I was just wondering how you would go about reading the data using the surreal scripts for use on a robot. Like all of the outputs from the controller.
    Hello there!
    We're glad you want to share something with the Instructables community!
    And we’re here to help you out.
    Due to some recent changes on the site, we are no longer able to publish stand-alone videos and other forms of incomplete posts. In order to be published live on the site, Instructables must consist of the following things:
    - Multiple steps showing how you made your project
    - Written instructions in each step
    - Your own original images
    Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
    We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
    If you have any questions, please feel free to ask right here or send us an email at service@instructables.com.
    Best,
    Instructables Community Manager
    Hello Community Manager,
    I believe I have modified my post to conform to your "Instructables Publishing Guide", however my post keeps getting denied.
    Can you provide more detailed information on what is required to successfully publish on your platform?
    Thanks
    I am sorry but according to the new publishing guidelines, each step in the instructable must have at least one picture.
