Light Sensor Circuit | Dark Sensor | Light Sensor | Simple Project
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello , Today in this video tutorial i am going to show you Step By Step
How to make a light sensor circuit using ldr
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Code
• Datasheet
• Pin Configuration Etc
AT ► https://circuit-diy.com/light-sensor-circuit-dark...
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Material
❖ Hardware Required ❖
► 9V Battery with Clip
► Breadboard
► Jumper Wires
► 470 ohm resistor
► 10k ohm resistor
► LDR
► BC547
► LED
❖ Circuit Diagram ❖
Link ► https://www.file-up.org/t1rc0yrsvjti
Step 2: Useful Steps
❖ Steps ❖
STEP # 1 ( Connect LDR )
► Connect LDR on bread board
STEP # 2 ( Connect BC547 transitor )
► Connect BC547 transistor on bread board
► Connect the base pin of transistor to LDR
STEP # 3 ( Connect LED )
► Connect LED on bread board
STEP # 4 ( Connect Resistor #1 )
► Connect 470 ohm resistor BTW +ve terminal of LED to the +ve rail of breadboard
STEP # 5 ( Connect Resistor #2 )
► Connect 10k ohm resistor BTW base pin of transistor and LDR to the -ve rail of breadboard
STEP # 6 ( Connect jumpers )
► Connect wire BTW -ve terminal of led to the collector pin of transistor
► Connect wire BTW emitter pin of transistor to the -ve rail of bread board
► Connect wire BTW the remaining LDR pin to the +ve rail of bread board
STEP # 7 ( Let's Test )
► Connect Battery & test circuit
    • Warm and Fuzzy Contest
    • Sweet Treats Challenge
    • Remix Contest
      Remix Contest
