Linux on XE303C12 Chromebook
67
Hello in this tutorial i will be showing how to boot Kali Linux from an SD card on the Samsung Chromebook 1.
This was a very hard project so have patience i will include an email so if any of you guys get stuck please email me and i will try to help you. So without any further adieu lets dive in.
Supplies:
what you will need for this project is simple
- a computer to work from
- a Chromebook (duh!)
- an SD card (the OS requires 5GB so i recommend a 32GB SD card)
Teacher Notes
Step 1: Operating System
So Kali Linux is not my favorite OS just its the one that works so that's what were going with.
Since the Chromebook is an ARM based laptop you cant just boot any Linux OS. So what took me longest was finding a bootable OS and hear is what i have... *drum-roll*
https://images.offensive-security.com/arm-images/...
If for some reason this image is no longer available please contact me because i have copy's downloaded.
Step 2: Flashing Sd Card
In order to flash the image to the SD card you must download and run balena etcher
https://www.balena.io/etcher/
After opening balena etcher click select image and navigate to the Kali Linux iso. Double click on it once you find it. Then click select drive. After selecting your SD card click FLASH! And you should be on your way.
Step 3: Developer Mode
In order to modify the chromebook you must have developer privileges. In order to switch your chromebook into developer mode you must hold down the esc and refresh keys then tap the power button. When you arrive at the screen pictured above press ctrl+d it will then ask you to verify just press enter. The chromebook will then take several minutes to reset. WARNING this step will wipe all your data and can not be avoided. From now on at start up it will show a screen informing you that os verification is off to continue start up press ctrl+d or wait 30 seconds.
Step 4: Modifying Chromebook BIOS
In order to boot from usb you must modify the Chromebooks BIOS. To do that you have to open a terminal, do that by pressing ctrl+alt+t. After the terminal opens type shell and hit enter. Congrats now you are into the shell terminal of the chromebook. Now it gets tricky type
#- sudo crossystem dev_boot_legacy=1 -#
and
#- sudo crossystem dev_boot_usb=1 -# then reboot
Step 5: Boot
This time at the os verification screen press ctrl+u and it should boot from usb (SD)
DO NOT LEAVE THERE IS WAY MORE TO BE DONE!!!!!!!!
First off all give yourself a pat on the back becuase the easy part is over and continue to next step.
Step 6: Resize Partitions
This may sound like an easy step but you can't just g-part for a number of reasons
1. g-parted does not yet exist and can not be installed
2.if you did g-part then chromebook will not boot because it messes up the root partition
ok so here it goes better open a terminal
# mkdir growpart
# cd growpart
# apt- WAIT!! we dont have repositories installed yet
ok forget the first part
# apt-get update
# apt-get install git aptitude
# apt-get update
ok now
# mkdir growpart
# cd growpart
# apt-get install cloud-guest-utils
# cd usr/bin
# ./growpart /dev/mmcblk1 2
# resize2fs /dev/mmcblk1p2 // ok this command should take awhile just wait
# cgpt repair /dev/mmcblk1
# reboot
Step 7: Finishing Up
Ok then now you can install g-parted
# apt-get install gparted
and then have fun i would recommend a few commands :
# apt-get update && apt-get upgrade
# apt-get install lxde // alt desktop environment ( i tried gnome but it does not work well )
# apt-get install synaptic // software manager
Allright so that should be all if you have any trouble at please contact me at
calvinshank38@gmail.com
Thanks and if this really helped you guys then please leave a like because this took a long time to put together.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    2 Discussions
