Live Edge Cookie Coffee Table
Introduction: Live Edge Cookie Coffee Table
About: Local woodworker looking to help people with their projects as much as possible and give new ideas. If you would like to donate for me to get better equipment and more information venmo is jakemyhre11
Ready to create a beautiful, easy wood cookie coffee table? I will take you step by step how to created this one. In total this project took me around an hour to create with the longest time being the sanding.
Here is a list of the exact tools I used:
18" Chainsaw
Dewalt Router
Drill
Orbital Sander
Orbital 60 Grit Sandpaper
Orbital 220 Grit Sandpaper
Orbital 400 Grit Sandpaper
Orbital 1000 Grit Sandpaper
Gloves
Eye Protection
Hair Pin Legs
Wood Finish
CAUTION!!!!
CHAINSAWS AND ROUTERS ARE DANGEROUS. USE SAFETY EQUIPMENT AND BE CAREFUL. NEVER WORK ALONE IN CASE OF AN INJURY.
Teacher Notes
Step 1: Finding the Right Log
Recently, a company came through and took a bunch of my neighbors big, mature trees in their backyards. Unfortunately, many of them were not happy and filled complaints to the city because of the hassle of the workers and the loses of their big trees. Their loss, my gain. I talked to the works and asked if I can take some logs off their hands, and they were fine with it. I took this log because it had a different, unique design and character to it. I decided this was the log I was going to use for this project.
I took my chainsaw to this log trying to make the straightest cut possible. I knew it did not have to be perfect since I was going to plane it down using a router jig I made. I cut it around 2"-2.5" thick leaving room to plane it down.
Step 2: Planing and Sanding (Lots of Sanding)
I hope you don't mind sanding. Like any project there will always being sanding down, but first we need to flatten it out by planning it down. If you do not have a large enough planner, I created by own router planning jig using some scrap wood. Here is a link to a simple jig for cheap https://www.youtube.com/watch?v=Q0H1C3AiFrw . I used a 1" router bit, but you can use a larger one or smaller one. If you use a smaller one it will obviously take longer.
After routering both sides of the cookie, there were still some line from the router. This will easily be taken off with the 60 grit sandpaper.
Now on to the endless sanding. I started out using 60 grit, then moved up to 220 grit, to 400 grit, then finishing it off with 1000 grit for a nice smooth finish.
Step 3: Finishing and Adding the Legs
After sanding it down to 1000 grit, I applied a Danish Oil finish. After the finish, draw out where you want the legs and screw them in. Make sure the cookie is as flat as possible to get the best results. Enjoy the beautiful masterpiece you made. It will be the talk of the night.
If you have any questions or comments, please let me know!
Be the First to Share
    • First Time Author Contest
    • Space Challenge
      Space Challenge
    • 3D Printed Contest
      3D Printed Contest
    2 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    Looks like a good table! I think you chose a good piece of wood :)
    612 Milling
    612 Milling
    Reply 4 months ago
    Thank you! I use this table everyday and when I have guest over, it is always the center of attention!
