Living Heart Succulent Planter
7,081
63
12
Introduction: Living Heart Succulent Planter
This succulent heart makes for a beautiful centerpiece or decoration inside or outside. It can be placed in a pot or sprouting straight from the ground in your garden. We created this heart in honor of our friend who is waiting for her Heart TransPLANT, get it? EM this one is for you!
Supplies:
1 Pot min. 7" circumference x 6.5" height
Rocks or gravel for bottom of pot
12 or more low growing, flat topped succulents and ground cover succulents (the more the better)
3 Sheets of paper
Ruler
Pen/Pencil
Scissors
Tape
min. 12" x 9" x 1.5" block of wood
Jigsaw cutter with wood blade
60 grit and 120 sandpaper
14ft of 12 gauge Galvanized Wire
5" length x 0.5" inside diameter aluminum tube
Wire cutters
Pliers
Green vinyl coated poultry netting
Heavy duty, PVC coated, garden training wire
4L Long fibered sphagnum moss
8qt Potting mix for succulents
Teacher Notes
Step 1: Create Heart Template
1a. Draw half a heart on your paper with max hight of 9", 6" wide, and center height of 7 1/4"
1b. Cut the half heart and use it to cut a second half heart.
1c. Tape both together at center.
Step 2: Create Heart Mold
2a. Use your paper heart template to draw it on your block of wood
2b. Using a jigsaw, cut the heart out at a 0degree angle
2c. Use your ruler to draw a heart inside of your cutout at 1" from the edge
2d. Cut at the inside heart with your jigsaw cutter at a 45degree angle
2e. Sand edges
Step 3: Shape Wire Heart
Cut 7ft of your 12 gauge wire with your wire cutters. Bend the center of your wire and place it at the dip of the heart and tape it down. Shape the rest around your mold and twist it at the bottom. Use pliers if needed.
Step 4: Shape Basket
4a. Place poultry netting on top of mold and shape down. Cut netting around the mold leaving some left over.
4b. Flip mold and netting over and place wire heart on top. Using the garden wire, weave netting and wire together. Cut excess netting and fold down tips to create a cleaner edge.
4c. Flip mold with netting again and press the netting down on mold to review shape. If needed, use garden wire to tighten the dip of the heart into shape.
Step 5: Repeat Step 3 & 4 to Create a Second Basket
Step 6: Fill and Close
6a. Line both baskets with Sphagnum Moss. Press down tightly to form a layer that is partially sticking out from the netting.
6b. Fill the rest completely with soil, water it, and fill some more until both baskets are tightly compressed and completely filled.
6c. Use a cardboard or thick paper to flip one of the baskets on top of the other without spilling its contents and then remove it.
6d. Weave both baskets together with the gardening wire.
Step 7: Set in Pot
7a. Weave the aluminium tube (5" length x 0.5" inside diameter) into the twisted wires at the bottom. Place the pot on the side to guide the height of the bottom bends. Bend the wires to create legs fitting tightly on the bottom and sides of the pot.
7b. Fill half of the pot with rocks or gravel for weight and the other half with soil.
Step 8: Add Succulents
Use your finger or stick to open a hole in the moss and dirt and insert the root of succulents. You can use a stick to further help you push them in. If the roots are too big, you can open up space in your netting with the pliers. The roots will grow and attach more securely with time.
Step 9: Enjoy!
Heart Contest
This is an entry in the
Heart Contest
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    12 Discussions
    JBonnetteArt
    JBonnetteArt
    6 days ago
    Very cool project! For those of us without access to saws, I was thinking it could also be done in other shapes by bending the wire around other things around the house. Sometimes it's possible to find shaped wooden boxes in craft stores and things like that.
    pemazzei
    pemazzei
    10 days ago
    Really nice! Any article on how to cultivate suculents? Greeetings from Brazil! Paulo
    jamesrobin
    jamesrobin
    Reply 10 days ago
    Try breaking off a leaf/section and putting the cut end in a moist medium (or water) and wait for roots to appear..
    pemazzei
    pemazzei
    Reply 9 days ago
    Thank you!
    ChrisWx
    ChrisWx
    9 days ago
    Can the moss be colored? Or maybe choose a different color (I understand it's color can vary quite a bit). The brown background is just a little off-putting in a heart shape.
    Unbottled
    Unbottled
    Reply 9 days ago
    It's an interesting thought! You could try spanish moss instead, which is silver. Or if you are adventurous, experimenting with cold water dye - fiber active dye on the moss prior to assembling. Or maybe dying it with natural methods like hibiscus? I guess the two key things to check is toxicity to the succulents and discoloration when watering. Let us know if you try it!
    backthirty
    backthirty
    Question 10 days ago on Step 3
    I realize succulents require very little water. How do you water this heart and how often?
    Assuming you would do with a spray bottle.
    Unbottled
    Unbottled
    Answer 9 days ago
    Hi! It varies depending on where you live or which plants you place, but more or less I shower it with water every week until it is saturated. I've read of also fertilizing them every other month with water soluble fertilizer to help keep them healthy.
    ibakkal
    ibakkal
    10 days ago
    Great project, thank you for the idea.
    chefspenser
    chefspenser
    10 days ago
    Great project-I love it!
    LynneDe
    LynneDe
    10 days ago
    These are beautiful! Thank you for sharing them with us, enabling us to have one as well. Blessings!
    Penolopy Bulnick
    Penolopy Bulnick
    12 days ago
    This is so super cute and really neat to learn how you got the shape, you could just keep making these once you have the mold :)
