LoRa E32 Device Arduino Shield (8Km Support)
89
Introduction: LoRa E32 Device Arduino Shield (8Km Support)
Software developer but I love electronics, wood, nature, and everything else as well.
E32-TTL-100 is a wireless transceiver module based on SX1278 from SEMTECH(can be transmitter and receiver both). It adopts LoRa spread spectrum technology, with this technology the transmitting distance and penetration ability of the module improved more than 1 times compared with traditional FSK.
Teacher Notes
Step 1: Here the Module
You can find module here AliExpress (3Km) - AliExpress (8Km)
Step 2: Arduino UNO Shield
I create a Library an Arduino shield very usefully to use.
The configuration is this:
LoRa_E32 e32ttl(4, 5, 3, 7, 6);
Than you can use all examples inside the library, you can use pin 6 and 7 to do a full connection or disable they and put M0 and M1 as you want with dipswitch.
Step 3: Start Prototype the PCB With CNC
As already I say I do a tutorial on how mill PCB and how to build CNC and I use that to create my prototype
Step 4: Than Test With Logic Analyzer My PCB
Step 5: Now We Are Going to Do a Massive Production.
Ready to go
Step 6: Shield Description
The shield have some jumper and dip switch to configure M0 and M1.If you want set M0 and M1 to a fixed value you must put jumper to F, if you want control via pin to P.If you set to F you must put dip switch on property value Low or High.
Step 7: Shopping List and PCB
AmountPart TypeProperties1Lora E32-TTL-100variant 1; voltage 3-5V; type Basic
1 DIP SWITCH channels 1; package dipswitch-02
2 Generic male header – 3 pins pins 3; pin spacing 0.1in (2.54mm); hole size 1.0mm,0.508mm; form ♂ (male); package THT; row single
1 Arduino Uno (Rev3) type Arduino UNO (Rev3)
3 4.7kΩ Resistor bands 4; tolerance ±5%; pin spacing 400 mil; package THT; resistance 4.7kΩ
3 1kΩ Resistor bands 4; tolerance ±5%; pin spacing 400 mil; package THT; resistance 1kΩ
3 2kΩ Resistor bands 4; tolerance ±5%; pin spacing 400 mil; package THT; resistance 2kΩ
3 10kΩ Resistor bands 4; tolerance ±5%; pin spacing 400 mil; package THT; resistance 10kΩ
1 Momentary Tactile Push Button package [THT]
1 Generic female header – 7 pins Pin spacing 0.1in (2.54mm);
2 Generic male/female header – 8 pins Pin spacing 0.1in (2.54mm);
1 Generic male/female header – 6 pins Pin spacing 0.1in (2.54mm);
1 Generic male/female header – 10 pins Pin spacing 0.1in (2.54mm);
You can get my PCB shield here from PcbWay.
Step 8: Here My Crtistmas Present
I chose this manufacturer because at the same cost it offers excellent quality, in the first screen it is possible to make countless options suitable for every need.
Step 9: Here the Soldering Video.
Step 10: Here the Result
Step 11: Thanks
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
