Lock Your Subaru for Surfing (Without the Alarm Going Off)
3,085
Introduction: Lock Your Subaru for Surfing (Without the Alarm Going Off)
About: I'm an 18 year old passionate about building, coding, and space science. Join me as I collect data from near space, build experimental rocket motors, and overengineer solutions to simple problems.
I was stoked when I got my Subaru. All-wheel drive meant I could off-road and explore. The hatchback trunk meant I could keep my surfboard in the car. And the trunk is at the perfect height for me to sit as I put on my wetsuit.
But, a problem I quickly discovered with my Subaru was locking it when I go surfing. See, I store my valet key in my wetsuit while I surf to ensure it doesn't get stolen from a hiding place. But, I could not figure out how to lock the entire car without the alarm going off.
You see, when I use the button on the keys or the button inside the car, the alarm goes off. So, I tried to lock each door using the manual lock on them, but the trunk remains unlocked.
When I turned to the internet for a solution, I couldn't find one. So, I spent an afternoon experimenting with the idea. And I figured it out!
Step 1: Lock the Car
Ensure all of the doors and trunk are closed, besides the driver side door. Next, use the lock button found on the driver's door (below the window control button) to lock the car. Ensure the valet key is in hand. Then, close the driver side door.
Step 2: Unlock the Front Door
Your Subaru alarm won't set for a few minutes. So, to disable it for the front door, use your valet key to unlock it. To do this, insert the key into the keyhole found on the driver side door. Once inserted, turn the key to the right - you will feel when it unlocks. Once unlocked, take the key out of the door. Then, open the door.
Step 3: Relock the Front Door
Finally, close the front door. Then, lock it using the valet key. To lock the door, use the door keyhole and turn the key to the left. Take out the key, and ensure the door is locked by pulling on the handle.
Step 4: Shred!
That's it. Secure the valet key in your wetsuit, and you're ready to rip!
To unlock your Subaru after your surf session:
- Remove the key from your wetsuit.
- Insert it into the door and twist right to unlock (I lick my key to remove salt and dry it before doing this step).
- Open the door and unlock the car using the button on the driver side door.
Safe and Secure Challenge
Be the First to Share
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    • Make it Move Contest 2020
    2 Discussions
    kolotour
    kolotour
    1 year ago
    Hi,
    On my 2012 Subaru I lock all the doors with the switch on the driver's door. Then manually unlock the driver's door with the flip switch near the handle. Exit the car and lock the driver's door with the key. Unlock it with the key when you return.
    AaronPrice
    AaronPrice
    Reply 1 year ago
    Cool! Sounds like a similar process.
