Low Cost VR Headset
Introduction: Low Cost VR Headset
My name is Sam KODO , since facebook release the Oculus quest and has stopped supporting` oculus rift I saw lot of people trying to make their own oculus Rift .
In this tuto , i will show you step by step how i built my first VR headset using Arduino nano and an LCD screen .
In this project you will need :
- An LCD Display HDMI :
https://www.amazon.com/Elecrow-Capacitive-interfac...
- An arduino Nano
https://www.amazon.com/ELEGOO-Arduino-ATmega328P-W...
-5mm of diameter for the lenses (Or could build for yourself using water bottles )
-A 9 axis gyroscope for head motion tracking
https://www.amazon.com/HiLetgo-Gyroscope-Accelerat...
-A 3D printer
-A Fan to cool down the screen card but is optional
Teacher Notes
Step 1: Testing the Screen
You need to make sure that your screen is supported by your computer card by connecting the power supply and the HDMI to your computer .
Right click to your desktop > displays settings > display , you should see your second screen somewhere ...
then click on that , your LCD screen should display your computer screen .
If everythings works well , then you are ready to move on the second step .
Step 2: Building Goggles Based on Your IPD
At this point you need to be accurate as you can , the IPD will enable your headset to give you a better immersive experience .
You can learn how to measure that by following this link :
http://doc-ok.org/?p=898
Once you have the correct distances values for your eyes then you can 3D print the goggles and another surface to hold the graphics card for the screen .
The dimension will depend on the screen size of your LCD
Step 3: Connecting Your MPU6050 to Your Arduino Nano
After connecting successfully the MPU6050 upload this sketch to your Arduino to test the Gyroscop .
By clicking on the serial Monitor , you should see values displaying while moving the Mpu650 Gyro in different axes and angles ...
Step 4: Testing the MPU6050 With Unity 3D
Before uploading the Sketch to your Arduino nano don t forget to install libraries to your Arduino folder , you can find the library from the GitHub link :
https://github.com/ElectronicCats/mpu6050
Step 5: The Final Code of Arduino
Once everything work perfectly then upload again this final code to your Arduino and open your Unity project .
Create a simple Game Object like a Cube and paste the Unity C# code below the Arduino Code from the file .
If everything is okay you should see your Cube or 3D object rotating when you move your Gyroscope .
Note that , to move the Camera from the Gyro to have a 360 view you need to attach the code to the camera from your scene and create a side to side screen from your project .
Step 6:
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
