Easy Valve Opener
Introduction: Easy Valve Opener
  1. A round metal pipe .5(or more) cm radius
  2. a square pipe 2 feet long,size depend on the valve
  3. a metal cutter
  4. a welding machine
Teacher Notes
Step 1: Methods
Step 1
from the bottom of the square pipe make a cut as shown in the figure
make the cut according to the size of the valve
Step 2
close the top opening using a a metal sheet
weld the metal sheet to the top
Step 3
weld the metal pipe to the top
that's all
finished
put the opening in the bottom into the valve as shown in the pic above
turn the metal pipe to clock wise to open the pipe and anticlockwise to close the valve
Build a Tool Contest
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
