MQ-2 Gas/Smoke Sensor With Arduino
About: Share Knowledge about Arduino, ESP,GSM,Basic Electronics, DIY PROJECTS, Raspberry pi
This Post shows how to build a smoke detector that beeps when it detects flammable gas or smoke.
The MQ-2 smoke sensor is sensitive to smoke and to the following flammable gases:
LPG
  • Butane
  • Propane
  • Methane
  • Alcoho
  • lHydrogen
The resistance of the sensor is different depending on the type of the gas.
The smoke sensor has a built-in potentiometer that allows you to adjust the sensor digital output (D0) threshold. This threshold sets the value above which the digital pin will output a HIGH signal.
Teacher Notes
Step 1: How Does It Work?
The voltage that the sensor outputs changes accordingly to the smoke/gas level that exists in the atmosphere. The sensor outputs a voltage that is proportional to the concentration of smoke/gas.
In other words, the relationship between voltage and gas concentration is the following:
  • The greater the gas concentration, the greater the output voltage
  • The lower the gas concentration, the lower the output voltage
The output can be an analog signal (A0) that can be read with an analog input of the Arduino or a digital output (D0) that can be read with a digital input of the Arduino.
Step 2: Pin Wiring
The MQ-2 sensor has 4 pins.
PinWiring to Arduino Uno
A0 Analog pins
D0 Digital pins
GND GND
VCC 5V
Step 3: Example: Gas Sensor With Arduino
In this example, you will read the sensor analog output voltage and when the smoke reaches a certain level, it will make sound a buzzer and a red LED will turn on.
When the output voltage is below that level, a green LED will be on.
Step 4: Parts Needed:
So, for this example, you’ll need:
  1. 1 x MQ-2 gas sensor
  2. Arduino UNO
  3. 1x Breadboard
  4. 1 x red LED
  5. 1 x green LED
  6. 1 x buzzer
  7. 3 x 220Ω resistor
  8. Jumper wires
Step 5: Schematics
Follow these schematics to complete the project:
Step 6: Code
Upload the following sketch to your Arduino board (feel free to adjust the variable sensorThres with a different threshold value):
int redLed = 12;
int greenLed = 11;
int buzzer = 10;
int smokeA0 = A5; // Your threshold value
int sensorThres = 400;
void setup() {
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(smokeA0, INPUT);
Serial.begin(9600); }
void loop() {
int analogSensor = analogRead(smokeA0);
Serial.print("Pin A0: ");
Serial.println(analogSensor); // Checks if it has reached the threshold value
if (analogSensor > sensorThres) {
digitalWrite(redLed, HIGH);
digitalWrite(greenLed, LOW);
tone(buzzer, 1000, 200); }
else {
digitalWrite(redLed, LOW);
digitalWrite(greenLed, HIGH);
noTone(buzzer);
delay(100);
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
