MQTT Integration
About: Cloud services for IoT projects
Teacher Notes
Step 1: How It Will Be Work?
You can switch on and off the LED of the ESP8266 with your mobile phone.
Step 2: Install the Example Code on Your IoT Device
ESP8266
You can simply clone the GitHub repository: https://github.com/IoTGuruLive/mqtt_example
Replace the WiFi SSID and password in the code, compile it and install it on an ESP8266 board.
Other device
You need to implement the MQTT topic subscription with the following parameters:
MQTT server name: mqtt.iotguru.live
MQTT server port: 1883
MQTT server username: mqttReader
MQTT server password: mqttReader
Subscription topic: sub/jPtvDXpb7zm375MtAKpELg/led
Subscription topic: sub/{nodeKey}/{field}
Step 3: Install the Android Application on Your Phone
Step 4: Sign in and Validate Your Email Address
Sign in and validate your email address, and you can see the dashboard with the node key, the field and the switch buttons. Also, you can use the application to draw charts of your measurements... :)
Be the First to Share
    • Assistive Tech Contest
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
