Magic Closet Lighting
1,789
I wanted to put a light inside my wife's clothes closet.
I didn't want to put in a regular light bulb & socket,as this would require a bulb, which gets warm, a switch which could get left on. I didn't want to have a warm bulb in tight quarters with flammable clothing. I also only wanted low voltage DC as this is safer and runs very cool.
The lights turn on soon as the doors are opened.
The strip lighting give very good light coverage through the closet.
So this is what I came up with.
Teacher Notes
Step 1:
Attach strip lighting on the inside of the closet wall.
Run a complete strip starting from the bottom of one side, over the top and back down the other side .
Step 2: Switch Installation
Locate and fasten the switch so when the door closes it presses on the switch.
Step 3: Soldering the Wires
The Lighting strip has a Positive terminal & a Negative terminal. And so does the DC Adapter.
Make sure you attach properly or you can burn out the LED strip.
Solder the negative wire from the adapter to the negative terminal end of the light strip.
Run a wire pair connected from the switch and solder one wire to the POSITIVE side of the light strip.
Solder and tape the two remaining ends of the wires together to complete the circuit.
Step 4: Completed
When all is done, you should have a very nicely lit closet with the coolness of just opening the door to turn on the light.
Low cost, easy project.
Indoor Lighting Contest
This is an entry in the
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    6 Discussions
    lewinskys
    17 days ago
    It made my wife happy. So it is a winner to me!
    seamster
    22 days ago
    Nice and simple. The best kind of project! : )
    SteveL75seamster
    Reply 21 days ago
    Thanks...and the other benefit is happy wife, happy life.
