Magic Magnet LEGO Minifigs
Introduction: Magic Magnet LEGO Minifigs
About: I run Design that Matters (DtM), a 501c3 nonprofit based in Redmond, WA. DtM collaborates with leading social entrepreneurs and hundreds of volunteers to design new products and services for the poor in dev...
We get a lot of weekend kid-visitors at the Design that Matters workshop. One of the most popular projects is the magical magnetic LEGO minifigure. LEGOs that hang upside down! Here's how to build them.
Supplies:
You'll need at least one LEGO minifig.
Magnets for LEGO minifig hands
Magnets for LEGO minifig feet
You may also want to apply some superglue (cyanoacrylate)
Teacher Notes
Step 1: Inserting the Neodymium Magnets
We often use small, powerful neodymium magnets in prototype assembly. They are much more convenient than fasteners and glue, especially when creating removable covers to hide batteries and microcontrollers.
Goofing around one weekend, we discovered that two of the neodymium magnets we stock in the workshop fit perfectly inside LEGO minifigs! The 1/8" cylinder magnets snap right into the minifig hands, and the 0.2" cylinder magnets are a squashy press-fit into the minifig feet.
When stuffing your magnets, you want to go slow, as some LEGO plastic colors are more brittle and can crack. The magnets are also tiny and can be a bit fiddly to line up. You may find it easier to stick the 0.2" magnets to a screwdriver or some other piece of metal and then press the LEGO minifig foot down onto the magnet.
You can tack each magnet in place with a blob of superglue (cyanoacrylate), especially if you cracked the foot when pushing it in.
Step 2: Throw Them Everywhere!
Throw your new superpowered magnetic LEGOs all over the place! Can you get a minifig to stick to the metal shop stool from across the room? Can you get a minifig to stick to the metal dividers in the drop ceiling?
For bonus points, you can tape an LED blinkie to the back of your minifig so that you can see it stuck to the ceiling even when the lights are off!
A word of warning: be careful not to give the magnet-stuffed LEGOs to dumb adults who like to swallow toys.
Magnets Challenge
This is an entry in the
Magnets Challenge
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
