Magnetic Soldering Aid
Introduction: Magnetic Soldering Aid
About: Retired to age but still working. I work a lot with technical constructions and manufacturing for my own part and for the school. Everything from furniture to machine parts. Has a workshop with among others ...
Magnetic soldering aid.
Tools for holding together steel wires during soldering. Mainly intended to be used in the construction of ball tracks. Ø1.5 - Ø3 mm. The parts are glued with epoxy adhesive or soldered together. A hole should be threaded M3.
The magnets should be facing North towards the south.With the screw you set a distance which is the sum of the two threads diameter.The wires are magnetized North and South respectively and are drawn to each other.
Magnetisk Lödhjälp.
Verktyg för att hålla samman ståltrådar vid lödning. Främst tänkt att användas vid konstruktion av kulbanor. Ø1,5 - Ø3 mm. Delarna limmas med epoxilim respektive löds samman. Ett hål ska gängas M3.
Magneterna ska vara vända Norr mot Söder. Med skruven ställer man in ett avstånd som är summan av de två trådarnas diameter. Trådarna magnetiseras Norr respektive Söder och dras till varandra.
Teacher Notes
Step 1: Magnetic Soldering Aid
Step 2: Magnetic Soldering Aid
Step 3: Magnetic Soldering Aid
Step 4: Magnetic Soldering Aid. Instructions.
Step 5: Magnetic Soldering Aid. Parts.
In addition to these parts, you need epoxy adhesive, the ability to solder and to thread an M3 hole.
Utöver dessa delar så behöver du epoxylim, möjlighet att löda och att gänga ett M3-hål.
Step 6: Magnetic Soldering. Drawing.
Build a Tool Contest
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • First Time Author Contest
    2 Discussions
    VajkF
    VajkF
    Tip 1 year ago
    You should move the magnets far from the soldering. Heat does destroy the magnets. Don't ask how I know.
    PerAnders
    PerAnders
    Reply 1 year ago
    The magnets just get a little warm not hot. Steel conducts heat rather poorly. The Curie Point is above 130 ° C (266 ° F). But you are right, that magnets are destroyed if they get too hot. I have tried solder magnets and it is possible if you do it quickly.
    Sincerely Anders
