Introduction: Make Goopy Cube Friends Out of Oogoo!
This instuctable includes detailed instructions on how to make cute, squishy, adorable colored cubes made from a material called "Oogoo" They are very easy to make, as well as being fun to make! These cubes can be colored, or drawn on by markers as well! Big thanks to mikey77 for making the tutorial that taught me to make Oogoo. Please go check out his page.
Step 1: Supplies
Supplies needed for making Oogoo:
100% Corn Starch
100% clear silicone caulk
Something to mix in such as a plastic cup or bucket
Optional:
Latex gloves
Oil based paints (For Color)
Step 2: Step 1: Mixing
For step one mix roughly 1 : 1 Mix ratio of Corn starch and Silicon. The mixture should look like small clumps of goop not necessarily stuck together, but mix until they do. If the mixture doesn't stick at all, add more Silicon, and if it sticks like crazy, add more Corn starch.
Also if you want a colored cube, now is the time to add paint to the mix.
Step 3: Sculpting
After the mixture is the right consistency, scoop up the mixture into your hands and roll it into a ball, the more you roll it, the more pliable. After the mixture is the consistency of squishy clay, you should pat the clay with Corn starch to keep it from sticking too much.
Step 4:
Next just flatten the sides of the Oogoo into a square shape. I didn't get too many pictures of this because my hands were covered with silicon.
Step 5: Enjoy!
Now just set the cube on a zip-lock bag, and rotate every now and then to evenly dry each side.
Optional:
while your new friends are drying, you can cut the cube in half and make it into a note holder!
You could also poke some holes into you friend so he can hold stuff!
Toy Challenge 2
