Make It Glow: a Flash Upgrade to Ultraviolet
4,000
44
15
Introduction: Make It Glow: a Flash Upgrade to Ultraviolet
About: I play with light
I needed an outlet for my build-brain (yes, it's a thing, I don't have to explain that here, do I?). I have always wanted to try UltraViolet Induced Visible Fluorescence (UVIVF) Photography, but I could never quite find the time or energy for it. After leaving a time-consuming research job, I finally had the time to explore, experiment, and play with light. So I decided to upgrade a flash.
This project was the perfect start to a series of one-day-builds as it was quick; I had all the parts I needed; it has been on the list for too long; and most importantly, I get to play with a different kind of light.
Perhaps it's my research and microscopy background, but my photography is not a means of artistic expression, it is a tool for exploration. A way to study or understand something new. A way to see the unseen.
Ok, let me be honest with you, this was 30ish% me just wanting to make stuff glow and 5% wanting to tell my nephew that I was working with invisible (UV) light. What can I say, I'm a big kid, I love glow in the dark stuff.
If you want a mini physics refresher, I will list fundamental concepts at the end. This information isn't necessary to upgrade the flash, but its always nice to understand how things work.
Ok, let's get to work.
W A R N I N G
The capacitor in a flash can cause serious injury or death!
If you do not know how to work safely with capacitors, STOP! Take your flash to a camera repair shop.Ask to have the plastic diffusers removed. Then come back and skip to step 5 & Install the Step-Ring/Filter Holder.
EYE SAFETY
UV light can cause ultraviolet keratitis (snow blindness/welder’s eye) macular degeneration, cataracts and cancer.
Always wear the appropriate safety glasses when working with UV lights. Look for safety glasses listed as Ultraviolet Radiation Blocking Spectacles/Glasses/Googles
Supplies:
UV capable Flash
52mm UV Bandpass filter
52mm IR Blocking filter
77-52mm Step Up Ring
Screwdriver (Flat and Philips head)
Black Tape
UV Safety Glasses
Why these items where used:
A Godox TT600 flash was used for the most basic of reasons…I had one. So, it got a considerable upgrade from plain ‘ol boring visible light to UV, and I couldn’t be happier with it. I mean, who doesn’t like glow in the dark stuff!
I used a 52-77 mm Step-Up Ring for a few reasons:
  • I could only find 52mm filters
  • I needed a way to attach 52mm filters to a 77mm-long flash head
  • I had a 52-77mm Step-Up Ring :)
I was out of gaff tape. What can I say, it happens.
Teacher Notes
Step 1: Remove Fasteners on Sides
  • Place the flash on its side
  • Use a small flat-head screwdriver to pop off the rubber covers
  • Use a small Phillips head screwdriver to remove 2 of the 3 screws (see image)
  • Flip the flash over and remove the rubber cover and 2 screws on the opposite side
    • Note that the rubber covers are not interchangeable. They are indexed for each side and labeled "R" and "L"
Step 2: Remove Cover Plate
  • Use a Phillips head screwdriver to remove the two screws securing the cover plate
  • Remove the cover plate
  • Take note of the orientation and stacking order of the plastic diffusers
    • This is just in case you want to revert the conversion
Step 3: Remove UV-cut Filters
  • Slide the clear plastic panels out
    • These block UV light
Step 4: Reassemble
  • Reinstall the cover plate and secure with its 2 screws
  • Reinstall the 2 screws and rubber cover on each side of the flash
Step 5: Install Filter Holder/Step Ring
Use tape to secure the Step Ring to the front of the flash head.
Learn from my mistake and use gaff tape. It will be easier to adjust if you do not align it perfectly on the first try. It will also be easier to remove if you want to revert the conversion.
  • Install the step ring with the 77mm side facing the flash. It will fit snugly around the flash head
  • Use a 2 inch piece of tape to secure the step ring to the side of the flash head
  • Flip the flash over and add a second piece of 2 inch tape to secure the step ring to the flash head
Step 6: Lightproof
Preventing light leaks is as important as wearing safety glasses.
  • Carefully wrap a strip of tape all the way around the step ring and flash head
    • Take care to line-up the tape with the step ring's edge
  • Once you are happy with the alignment, press the tape down onto the flash head
    • This will both, secure the step ring to the flash, and keep light from leaking
  • Add a second layer if you have any gaps in the tape
Step 7: Install Filters
Simply thread the filter onto the step ring
  • Install the IR blocking filter
  • Install the U-340 filter
Step 8: Put on UV Safety Glasses
Put on UV safety glasses before powering up your flash
Step 9: Make It Glow!
Test your new UV flash out on some flowers or other household items.
Step 10: Notes on Light
  • The electromagnetic spectrum is a range of wavelengths of electromagnetic radiation. Simply stated, It's all kinds of light: Gamma, X-ray, UV, Visible, Infrared, Microwave, and Radio.
  • For this discussion, we only care about Visible, Ultraviolet, and Infrared (IR).
  • The human eye cannot see most of the electromagnetic spectrum, only a small range.
  • Visible light has wavelengths between ~400 to ~700 nm.
    • As the name suggests, it is what we can see.
  • UV is below 400 nm.
  • Infrared is above 700 nm.
    • This is something most camera sensors can detect, at least in the low range.
    • For "normal" photography, visible light drowns out the IR, so we don't worry about it.
    • In UVIVF photography, there is little to no visible light, so the small amount of IR light contaminates our final image.
  • For UVIVF, we only want UV light from the flash.
    • Flash tubes (the bulbs) are capable of emitting UV, visible & IR so we need to filter out a lot of light.
    • A UV bandpass filter allows UV light to pass while blocking visible light.
      • These filters usually leak a little IR.
    • An IR cut filter blocks IR.
    • If we stack a UV bandpass filter and a IR cut filter, we block Visible and IR while allowing UV light to pass.
  • Fluorescence or any Photoluminescence occurs when a material absorbs electromagnetic radiation of a discreet wavelength and then emits a different, generally longer wavelength (lower energy) light along with a little heat.
  • When a subject absorbs UV light, it excites electrons to a higher energy level. In this excited state, the electron is unstable. To return to its ground state (where it started), it emits the absorbed energy as visible light and heat. That's why stuff glows in the dark.
Any questions? Just drop them in the comments.
Make it Glow Contest
Second Prize in the
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    15 Discussions
    davinger
    davinger
    14 days ago
    I LOVE this project! I’m curious about the need for UV glasses. Is this to see UV or to protect your eyes from it? Are there levels of UV that are bad for your eyes?
    inkybreadcrumbs
    inkybreadcrumbs
    Reply 13 days ago
    The glasses are to protect your eyes. Yes UV is bad for your eyes.
    BakerBoy7
    BakerBoy7
    13 days ago
    Great Instructable! Well written with fantastic step by step pics.
    I very much want to emulate the UV macro work of Nicky Bay. I have tried in the past to use a UV LED torch but the light was insufficient. Very tempted to try this. Also worth noting that you need to remove any UV filter from the camera.
    inkybreadcrumbs
    inkybreadcrumbs
    Reply 13 days ago
    Thanks for the kind words.
    Bay's macro work is fantastic. I love the spider closeups.
    You do not need a modified camera for this. We are recording the visible light that the UV induced
    TonK5
    TonK5
    Tip 13 days ago on Step 10
    Note that digital camera's often have a UV blocking filter in front of the sensor, reducing the sensitivity for UV. This filter can be taken out but clearly, this is more labor intensive and you risk ruining your camera.
    onetruegod
    onetruegod
    Reply 13 days ago
    Yes but he is not taking UV photos. It is UV induced fluorescence. As explained in step 10, the subject emits light at a longer wavelength ie visible light. So the camera's UV filter is not a problem.
    TonK5
    TonK5
    Reply 13 days ago
    Of course, thank you for highlighting this. I have mentioned this since it may widen up the application of the flash.
    Infra red is not a problem on most digital camera's, handy thing to know since this allows you to test a remote control for your tv set and others.... just look through the camera at the Infra red LED and press a button on the remote...
    inkybreadcrumbs
    inkybreadcrumbs
    Reply 13 days ago
    As mentioned, this is UV induced visible fluorescence, so you do not need to mod the camera. If you wanted to do Reflectace UV, you could use this flash with a modified camera.
    Again, as mentioned, IR becomes a problem because we are cutting all visible light from the flash.
    Mr&MrsA
    Mr&MrsA
    18 days ago
    I know nothing about any of this but could someone put the flash in a uv protected box with an item like one of the flowers you shared in it and make it a nightlight or centerpiece of sorts? Or am I misunderstanding how this works? Either way, this is a beautiful and awesome project! Tha
    ElectroFrank
    ElectroFrank
    Reply 14 days ago
    Illuminate your flowers with ordinary UV LEDs. They are cheap and easy to use, but do not give out enough UV to be dangerous. 12V UV LED strip is also available. There are Instructables on connecting and using LEDs.
    Attached: simple circuit for 3 UV 5mm LEDs to connect to a 12V adaptor.
    Ensure correct polarity. The long leg of an LED is the + positive side. Use "strawhat" LEDs for a wide angle of light. Use a 100 Ohm resistor to limit the current through the LEDs. (Or they burn out.) Shield the LEDs from the viewpoint for best effect.
    inkybreadcrumbs
    inkybreadcrumbs
    Reply 14 days ago
    All UV is dangerous in the right dose. with small lights, just make sure you keep it pointed to your subject.
    But there are some monster UV LEDs out there so use caution whenever using working with UV
    BardP
    BardP
    Reply 13 days ago
    As long as the "uv protected box" actually is blocking the UV light properly, this will be safe. (Wear UV protective glasses and test the light coming out of the box with some fluorescent material to verify that there is little or no UV coming out.)
    inkybreadcrumbs
    inkybreadcrumbs
    Reply 18 days ago
    If I understand your question, yes. You could make a something like that. It likely would not give off enough light for a nightlight, but if you just wanted something pretty or different, it would work.
    For something like that, I would use a UV flashlight not a flash. The glowing only lasts as long as the flash burst.
    jessyratfink
    jessyratfink
    19 days ago
    Oooohhh what a fantastic idea! Almost makes me want to buy a second external flash :)
    inkybreadcrumbs
    inkybreadcrumbs
    Reply 18 days ago
    Thanks. :) BTW Godox and Yungnuo flashes are really inexpensive. Yungnuo conversions are similar. They just have metal tabs instead of screws.
