Make PVC Pipe Cage
About: I enjoy making new Instructable
In this tutorial I am going to make PVC pipe cage by using pvc pipes of the length of 1 inches which is a normal pvc pipe for water supply but can be use in a lot of projects , making pvc cage by using pvc pipe is simple and easy project.
Supplies:
3 way elbow x 8
Pvc pipes 12 inches length x 16
Net wire according to size
Cable Ties
Elbow x 4
Door Knob
1 inches screws x 24
Door hinge
Door lock
16"x16" plyboard
Teacher Notes
Step 1: Making Joints
Join all the pvc pipes to 3 way elbows making a square shape
Step 2: Putting Net
put meal net over the structure , it will be easy if it is cut by it's size to form on all it's 4 sides covering in one piece.
Tighten the net on all it's sides by pvc so it stays strongly and doesn't move from the structure.
Step 3: Make Door
Take 4 elbows and make a square shape ,put the net over it and tighten it with the cable ties.
Step 4: Place Necessary Things
Put the door hinge on the door and structure and tighten it with the screws ,make hole for door knob and set it up , place the door lock and put it on with screws.
Step 5: Making Base
Place the plyboard on the bottom side which we didn't cover by net , tighten it with the screws on the bottom structure of the cage.
The cage is ready for bird,rabbit,cat etc
If you like this tutorial Please like share and vote
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
