Make Ultra Tiny 3D Prints
Introduction: Make Ultra Tiny 3D Prints
About: I am a Maker since i was 10. After my apprenticeship as Mechatronic Technician i was able to do all these things i want every time to do. I built a 3D printer as the 3D printers just fresh on the makrt publi...
Sometimes 3d prints are needed that are smaller than normal. Some would like to print a car for their model railroad. Others want to print gear parts for their model cars or some spare parts are so small that a normal printer has difficulties. A normal 3d printer cannot do that. I will show you how you can convert your 3d printer to print 3d prints in an incredibly small size.
Supplies:
You will need:
3D Printer with MK5 extruder recommended
Nozzle with 0.2mm for your Extruder
3D Software with adjustable Parameters like Cura, Slic3r, etc.
a bit time to test
Teacher Notes
Step 1: Replace the Nozzle
Step 1:
Lift your Z axis to get a better accessibility.
Step 2:
Heat your extruder to make plastic sticking in your extruder soft
(I recommend it. It works at some printers without heat up)
Step 3:
Remove nozzle with a fitting spanner. It is recommended to hold your heating block with some pliers.
Step 4:
Screw the new nozzle in. Thinghten it with a spanner.
Warning: the work will be done on a heated extruder. Risk of burns
Step 2: Configuration
At first, download a model import and scale it to the size you want.
Now you have to configure your printer software.
In my case i used Cura.
At first you have to adjust the nozzle size to 0.2 mm.
After that reduce the printing speed (my printer works fine with max 30 mm/s).
Now reduce the shell thickness to 0.4 mm like a normal print at 2x nozzle size.
At the end, reduce the layer height. Some parameters work from 0.05 mm to 0.2 mm but you should never go over 0.2 mm.
Now simulate the toolpaths to see any configuration errors.
Step 3: Have Fun
For many hobby model builders, a 3D printer that can print small things is indispensable.
For example, I built a complete chassis for a 1:26 model from Revell with suspension, power steering and rear-wheel drive, but with the engine sitting in the front. Unthinkable with a normal 3D printer.
Stay creative and have fun.
Tiny Speed Challenge
This is an entry in the
Be the First to Share
    • Tiny Speed Challenge
    • Woodworking Contest
      Woodworking Contest
    • Trash to Treasure Contest
    4 Discussions
    NeilRG
    NeilRG
    3 days ago
    Pretty clever printing and painting that oversize coin! It looks SO real. But I wasn't fooled :)
    schraubenonkel
    schraubenonkel
    Reply 2 days ago
    No that is a real 2 Euro coin the car is really that small. If you can not believe that, it is your choice.
    NeilRG
    NeilRG
    Reply 1 day ago
    I actually have 4 3d printers and APPRECIATED your instructable. My earlier comment was a (failed) attempt at humor. No offense intended.
    schraubenonkel
    schraubenonkel
    Reply 1 day ago
    Oh ähm.... Okay it was obviously a failed joke. Thanks for liking my instructable
