Make Your Own 4S Lithium Battery Pack
About: Hi my name is Steve and i'm a Creative and I got Technical skills i can build anything just stick to my account . I'm a YouTuber so you also can see my all videos here https://www.youtube.com/SteveWillsonKujur
Hey! everyone My name is Steve.
Today I'm going to show you How to Make 4S 2P lithium Battery Pack
Click Here to See The Video
Let's Start
Teacher Notes
Step 1: Gallery
Step 2: Features
Output Power
  • 5200 mAh @ 16.8V
Input Power " Charging "
  • 2000 mAh Constant Current
  • 16.8v Constant Voltage
Built-in Protection
  • Over Load Protection
  • Short Circuit Protection
  • Over Heat Protection
Step 3: Things You Need
Recommended Products
2. https://amzn.to/2yr81bX
Where To Buy "Cheapest"
Banggood
1. Connector Holder - https://goo.gl/Cyk76V
2. XT60 Connectors - https://goo.gl/Tm4rRQ
3. SUNKKO 787A+ Spot Welder - https://amzn.to/2yr81bX
4. 18650 Battery Pack Spacer - https://goo.gl/ba67t6
5. Nickel Plated Steel Strip - https://goo.gl/GgpGdq
6. Battery Protection board BMS - https://goo.gl/zcgqBJ
7. Black Silicone Wire Cable - https://goo.gl/bMmPid
8. Red Silicone Wire Cable - https://goo.gl/qMCbD7
9. Kapton Tape - https://goo.gl/KPagVx
10. Mustool® MT223 60W Soldering Iron - https://goo.gl/iH7d5C
Amazon
2. XT60 Connectors - http://amzn.to/2gShZaJ
3. SUNKKO 787A+ Spot Welder - https://amzn.to/2M93P2b
4. 18650 Battery Pack Spacer - https://amzn.to/2M8HSka
5. Nickel Plated Steel Strip - https://amzn.to/2yqNuE3
6. Battery Protection board BMS - https://amzn.to/2trNVsm
7. Black Silicone Wire Cable - https://amzn.to/2MDAsWV
8. Red Silicone Wire Cable - https://amzn.to/2MDAsWV
9. Kapton Tape - https://amzn.to/2K3piJt
10. Mustool® MT223 60W Soldering Iron - https://amzn.to/2K5NBcZ
Aliexpress
Step 4: Assembly
First Step
  • Make sure all the batteries are at the same voltage and same capacity
  • Now put one by one into the battery holder
  • Now use Kapton tape to tape it all
Kapton Tape - it is used to avoid the heat basically it is a heat resistance tape
Step 5: Welding
Second Step
  • Now cut down the Nikkle plated strip tape at right length "See the image"
  • First, make a pair of 2 parallel battery as shown in the picture
  • and then connect all the 4 pair in series
  • This connection is called 4S 2P
  • You can also see the connection diagram above
4S - Stands for 4 Series
2P - Stands for 2 Parallel
Step 6: Meetup
  • Now use a multimeter to measure the battery voltage now I got a reading of 16.49V it may differ from mine reading is totally depends upon the charge of the battery
  • Now use Kapton tape to cover the back side of the BMS with several layers
  • Now use a double-sided tape to stick the BMS to the Battery
Step 7:
  • Now use a soldering iron to pre-tin the solder pad
  • Now connect all the pads with small wire as shown in the images
  • You can also see the pictures as reference
Step 8: Favoriate T60
  • I love to use XT60 everywhere
  • Now I used the special holder to hold the XT60
  • And used some 14AWG silicone wire and soldered on the XT60
  • Now used some heat-shrink tube to secure the connection
Step 9: Final Step
  • Now I soldered the XT60 wire to the BMS
  • And now used a multimeter to see the battery pack is working
  • It's done
You Just Made It Thank you for visiting my Instructables
Stay tuned for next Projects
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    3 Discussions
    DarianK4
    Question 1 year ago on Step 7
    A little confused by the wiring diagram. the picture showing the wires soldered onto the pcb is a tad blurry, and the diagram provided by banggood shows the connections for the port on the side rather than the pads.
    1 answer
    MaxxB1
    1 year ago
    How do you charge this pack?
