Make Your Own Hobby Jumper Cables
About: I love robotics and all things electronic. I am also obsessed with Marvel and Star Wars.
My budget is small, so these can save some money and help your soldering skills.
Supplies:
Heat shrink tubing
As many alligator clips as you want
Solder and iron
Red and black wire
Hair dryer or heat gun
Multimeter (opt.)
Teacher Notes
Step 1: Soldering
Put your wire in one clip and turn on your iron. Touch the solder to the tip of your iron and let it drip onto the wire and clip. The end with the wire is the non-clip end, look at the pix to see what I mean.
Step 2: Testing
Take your multimeter and clip one cable on to the leads of your multimeter. Turn it on to the continuity or lowest ohm setting and it should beep or show a very low ohm reading. If you don't have a multimeter, don't worry about this step.
Step 3: Done
Use for testing circuits and fun!
Thanks for reading,
g3holliday
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
