Make a Brass Soldering Iron Tip (, How I ...)
54,051
49
48
Introduction: Make a Brass Soldering Iron Tip (, How I ...)
About: I'm a figment of my own imagination. ---- To Win the war on Terra Means to END the WORLD. How about a nice game of Chess? ---- I'm chilling, but forgive me for sometimes believing I invented everything.
Well I don't have a very well tooled machine shop at all,
but my first soldering iron had a brass or bronze tip,
and other people have remarked about how new tips
don't last as long as rare or unobtainable brass ones
from times gone by.
I can't say how good this is yet since I just made it
and will compare it to the other tips as far as wearing
out goes. Brass is supposed to be copper and zinc,
but just about any other yellow alloy using copper
may also be called brass, and dark coppers bronze.
Another reason I want to make soldering tips is that
I plan to try to make a very tiny soldering iron for SMD's
that I will have to solder under a microscope for
interesting one-time projects. One such project
may be phonographic (sounds groovy!) in nature.
Teacher Notes
Step 1: What You Need
Tools and Parts. Here are the ones I used:
1.A regular moderately cheap soldering iron.
(not the 99 cent ones that melt in your hand though)
2.A brass rod similar in diameter to the iron's non-brass tip.
3.A rotary motor tool kit like a dremel.
4.safety glasses
5.solder
6.flux
7.Something not very important to solder the first time.
Step 2: About Two Different Ways
I did it two different ways by forgetting how I did it first.
Probably the easiest way is to grind or taper one end
of a long brass rod and then make rough "threads"
similar to the ones the original non-brass tip has,
screw it into the soldering iron, cut it off an inch or so,
and then sharpen the end that was just separated from
the rod. To make a long story short that's how I made
the first tip.
But I'll continue with the "hard way" because it has
similar steps that may be important details. The hard way
is to sharpen it first, cut it off, and then thread it.
If you have a nut or die it may help, but grinding away
at the Slightly tapered and crudely threaded end is what
I did to make the brass tip screw into the soldering iron.
The hard way is sharpening the end of the rod as the
soldering tip end First. Details follow. Both ways are
probably wrong in the mind of a machinist, but they
made tips, so they do work.
Step 3: Making the Tip the Harder Way...
Here I shined up the brass rod which was temporarily used
as part of an antenna, using steel wool. There are probably
other ways to shine it up, like buffing or using something called
"brasso". Feel free to comment on my unskilled machining "errors"
and what better ways are the best.
Then I sharpened the end of the rod, in a shape that's good for
soldering. Pointy, and kind of flat.
This is the "hard way" tip. The "easy way" tip was just cut at a
sharp diagonal leaving an elliptical facet on the soldering end.
Then I compared the size of the original tip to the rod and
cut it off there.
Then I "scored" and slightly tapered the cut off end of the new
brass tip I'm making and using vise-grips, cut screw-thread-like
slightly diagonal notches in a roughly spiral pattern. (In the
"easy way" I did this first and screwed it into the iron before
cutting it off.)
Step 4: Getting the Tip Ready to Solder
Again the easy tip was made into a screw at one end of the brass rod,
screwed into the soldering iron, and then cut off of the rest of the rod.
It was also polished shiny. (I haven't used the hard-way tip yet.)
Then I dipped the tip halfway into flux, wrapped it up in high-tin solder
(with no lead, just because it seemed like a good idea to "tin" it),
and plugged in the soldering iron with the brass tip. The solder melted
as it heated up and I added more, coating about half the brass with
the tin. Regular rosin core solder can probably also be used. This is
a totally experimental make anyway, so if it works it works.
Step 5: Trying It Out - Solder a Job
I decided to use this to fix an old invention that has no
practical purpose that I made in my youth, which has
old Germanium transistors that must have shorted out.
It's a weird circuit that buzzed if you touch it.
So far, the soldering brass seems great.
Step 6: Check the Condition of the Tip After Use
The oval tapered soldering tip surface still seems nice and flat and shiny!
I wonder how long it will last.
Remember, this is a totally unskilled experiment in soldering-tip-makeing.
Results may vary, Comments welcome! Are brass tips better or not?
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Arduino Contest 2020
    48 Discussions
    akmaly
    akmaly
    2 months ago
    Very beautiful work I wanna ask does it work on pcb to sold like copper or alloy tips ?
    TravisB45
    TravisB45
    4 years ago
    Worked awesome... I bought a 3' long brass rod for $3, and I'll never need to buy a soldering tip again...
    turbiny
    turbiny
    5 years ago on Step 6
    i just use around 5awg cooper wire, its cheap and i can shape to whatever point i need it.
    EPAIII
    EPAIII
    5 years ago on Introduction
    As others have said, the "old" tips were copper because it conducts heat very well. But copper dissolves in solder so the tip gradually wears away. Since brass has a high copper content, I expect it will also dissolve. Most of the iron makers went to steel plated tips. Copper on the inside to conduct the heat and steel on the outside. These tips work just as well and last a lot longer: I have some that are over 40 years old and still perfect.
    Solder guns still use copper tips. In fact, you can just use 10 or 12 gauge, solid copper wire to fashion your own.
    Scott_Tx
    Scott_Tx
    13 years ago on Introduction
    You could form the tip by chucking it into a drill and grinding it down on a stone. And if you could find a nut with the same threading as the soldering iron you could use that as a die to cut the threads with.
    VIRON
    VIRON
    Reply 13 years ago on Introduction
    Good ideas. Especially I'd rather get the tip stuck or broke in a nut than an iron. Hmmm that happens alot to regular tips when they're old, so they are rarely replaced; I wonder if there's some way to prevent that.
    FN64
    FN64
    When the tip is new put a very light coat of graphite on the threads. Recoat it a couple times a year. Between the graphite and the action of physically removing, cleaning & re-inserting the tip will assure you can take it out when necessary. Over time oxidation will build up on the threads causing it to stick. This should resolve it.. FN
    PointyOintment
    PointyOintment
    Does that interfere with the heat being conducted from the heater to the tip?
    VIRON
    VIRON
    Thanks, sounds good, I'll try that.
    Rukbat
    Rukbat
    8 years ago on Introduction
    1) The old tips were pure copper, not brass.
    2) The "new" (actually a few decades old, at least) "iron" tips are actually better and last longer. (My current "pcb tip" is about 18 years old and still looks the same as when it was new (plus heat discoloration).
    3) If you want to make a tip, get a real die for the thread the iron uses. (Different irons use different threads. Take the original tip to a GOOD hardware store [or a machinist] and find out what thread it is.) Thread the end of the rod. Cut off the length you want. Shape the cut-off end.
    For a new tip, just flux it, heat it and, as it starts to get hot enough, rub the normal solder you're going to use all over it. A thin film is enough. Once it's all "tinned" (that actually means "covered in solder", not "covered in tin"), wipe it on a wet sponge (which you should always have handy when you're using the iron - keeping the tip clean is an important part of good soldering).
    My ways may not be the ones you'll read in the books, but most of those books weren't written (the authors weren't even born yet) when I learned to solder about 62 years ago. And my ways have worked for 62 years so far.
    Agent24
    Agent24
    8 years ago on Step 6
    So, how well did the brass tip compare to normal iron-plated copper tips?
    Did it last longer, or did it fail sooner?
    codongolev
    codongolev
    9 years ago on Introduction
    my soldering iron tip broke off inside the iron and I couldn't get it out, so I drilled out the tip and jammed a nail in there. it works. (I used my blowtorch to flood the connection with solder to get a good thermal connection.)
    PointyOintment
    I have a soldering iron that looks the same as yours, except mine has a base and is 20/40W. The trouble is that the tip has female screw threads, i.e. it screws on around the other part. Is there an easyish way to make a converter or something?
    I might attach a photo later. The path from my camera to here is very circuitous.
    technosasquatch
    technosasquatch
    http://www.proskit.com/soldering-assy/tips/5PK-353-T2 the tips are up on the page, cause I just ordered some from them.
    PointyOintment
    PointyOintment
    To clarify, I was looking for tips different from the type that came with the iron. Those tips, or similar ones (the ones I don't want), can also be found at Canadian Tire (linked in my other comment) but your source seems cheaper.
    technosasquatch
    technosasquatch
    they also have chisel tip, but you'll have to email customer support to add them to the site
    MilotisX
    MilotisX
    i have that iron! and i bought a few tips only to find that the ends looked the same on the iron and the tip. i was like FFFUUUUU-
    PointyOintment
    PointyOintment
    Reply 11 years ago on Introduction
    Update: I have found out that it is a Nexxtech-branded Mastercraft soldering station, model 58-6301-2.
    The only tips I can find for it are the same as the one it comes with.
    Soldering station
    petre
    petre
    petre says: forgot to mention i use that never-seez compound on all my sparkplugs also. i have never had a frozen plug since using it.
    petre
    petre
    petre says; my iron is also a weller and a 10/24 brass screw fits perfect. a product called never-seez is very good for those threads.rated at 2000 degrees f.
