Introduction: Make a Diamond Lamp Combined Wood and Iron
In this project I built a lamp from a combination of wood and iron Of course I used recycled materials like building iron and wooden panels from a storage box and the perfect result! My wife loved it.
Step 1: Phase the Iron Base of the Lamp
In the first stage of building the lamp, I use the iron lamp base for a building that I found among all my curtains. I use this iron because I want to create a lamp made of recycled materials and also because I love its texture. At this point I cut 6 pieces of iron 52 cm and flattened them to the desired angles...
Step 2: The Welding Phase of the Lamp Base
The next step is the step where I start to weld all the iron that I cut and create the diamond shape of the lamp. To maintain an even spacing between the irons, I use 6-rib nuts so I maintain an even spacing without creating a static shape for the base of the lamp
Step 3: The Base Coloring Step
Once the base is ready I go to the paint job. I paint the base with a matte black color that I love
Step 4: Combine Cutting Pieces of Wood
Next, I start cutting the 6 pieces of wood I dismantled from an old storage box. I used a beautiful tree but unfortunately I do not know what kind of tree it is I would love to have someone can tell me in the comments...
Step 5: Combine the Wood Connection With the Iron
The next step is the one I like most ... the stage where I start to connect the pieces of wood to the iron base. The combination of iron and wood is the combination I like most in my opinion it is a winning connection!
Step 6: The Final Stage
last stage! Connecting a lamp house to the lighting base. Then plug in the power for testing to make sure everything works. And this is what a beauty I made a diamond-shaped lighting fixture from a combination of wood and iron like I love and everything from recycled materials I found in garbage. The perfect result Tell me in the comments Did you like it? You can also watch the full video on my YouTube channel
Runner Up in the
Indoor Lighting Contest
