Makey Makey and the Tech Deck
575
5
Introduction: Makey Makey and the Tech Deck
If your students enjoy using the Tech Deck then this is a project for your class. We combined Scratch programming and converted a Tech Deck to use with the Makey Makey to make an engaging project. Students learned about physical computing and enjoyed every step of the process.
Supplies:
  1. Makey Makey Kit
  2. Alligator clips included in the MakeyMakey Kit
  3. Tape: copper, clear, masking, and hot glue
  4. Tin foil
  5. Dowel (any size)
  6. 8x12 piece of cardboard (any size available)
  7. Popsicle sticks
  8. Tech Deck
  9. Scratch account
Links to the Scratch projects:
  1. Skate 1: https://scratch.mit.edu/projects/329528717
  2. Skate 2: https://scratch.mit.edu/projects/342505244
Teacher Notes
Step 1: Create the Scratch Projects
First, the students coded their projects and then the physical controllers were created.
Skate 1:https://scratch.mit.edu/projects/329528717
Step 2: Preparing the Rails
The popsicle sticks provided the base for the rails and the students used hot glue to create the rail. After the rail was created, they used copper tape to cover the exposed areas.
Step 3: Preparing the Tech Deck
Students put copper tape on the bottom and the top of the board to create a complete circuit.
Step 4: Creating a Bracelet for Earth/Ground
The students created a bracelet and attached it to earth/ground on the Makey Makey
Step 5: Putting It All Together
The rails were attached to a large piece of cardboard and they covered it with aluminum foil to increase the size of their skate park. This project required many iterations as sometimes they had to fix the code and sometimes they fixed the physical skate park. They enjoyed every minute of this process as they were able to extend their passion with the Tech Deck.
If you improved on this project and/or if you made one, please let us know.
Makey Makey Contest
Makey Makey Contest
Be the First to Share
    • Distance Learning with Tinkercad Contest
    • Sculpting Challenge
      Sculpting Challenge
    • Cardboard Speed Challenge
    2 Discussions
    MakeyMakey
    MakeyMakey
    6 weeks ago
    Whoa! This is a great mashup! We love how innovative this switch is with the Tech Deck!
    Penolopy Bulnick
    Penolopy Bulnick
    6 weeks ago
    This looks like a great use for Makey Makey :)
