Introduction: Making Traffic Light With CloudX
I made this.
Step 1: FOUR WAY TRAFFIC LIGHT WITH CLOUDX MICROCONTROLLER
Using CloudX development board for traffic control is as simple as ABC; its as eazy as "Every one can do It".
On this project, i have implemented functions in this project for both educational purpose and industrial use. None the less, it is better as a programmer, it helps in debugging. The code is simple to read, modify and implement.
NOTE: for more info on CloudX follow this link
So it goes thus:
/* <br> * File: main.c * Author: Ogboye Godwin * * Created on June 25, 2018, 12:12 PM */
#include <CloudX/M633.h> #include <CloudX/Serial.h><br><cloudx m633.h=""><cloudx serial.h=""> setup(){</cloudx></cloudx>
int answer,x; for(x=0; x<32; x++){ answer=answer+x; } int dfr; dfr=x; loop(){} }*/ #define R1 pin1 #define Y1 pin2 #define G1 pin3 #define R2 pin4 #define G2 pin5 #define Y2 pin6 #define R3 pin7 #define G3 pin8 #define Y3 pin9 #define R4 pin10 #define Y4 pin11 #define G4 pin12 int active;
void blinka(){ if(active==1){ for(int yu=0; yu<10; yu++){ delayms(1000); Y1 =~ Y1; Y2 =~ Y2; } } if(active==2){ for(int yu=0; yu<10; yu++){ delayms(1000); Y2 =~ Y2; Y3 =~ Y3; } } if(active==3){ for(int yu=0; yu<10; yu++){ delayms(1000); Y3 =~ Y3; Y4 =~ Y4; } } if(active==4){ for(int yu=0; yu<10; yu++){ delayms(1000); Y4 =~ Y4; Y1 =~ Y1; } } } all_off(){ R1 = OFF; R2 = OFF; R3 = OFF; R4 = OFF; Y1 = OFF; Y2 = OFF; Y3 = OFF; Y4 = OFF; G1 = OFF; G2 = OFF; G3 = OFF; G4 = OFF; active=0; } all_on(){ R1 = ON; Y1 = ON; G1 = ON; R2 = ON; Y2 = ON; G2 = ON; R3 = ON; Y3 = ON; G3 = ON; R4 = ON; Y4 = ON; G4 = ON; active=0; } road1_go(){ R1 = OFF; Y1 = OFF; G1 = ON; R2 = ON; Y2 = OFF; G2 = OFF; R3 = ON; Y3 = OFF; G3 = OFF; R4 = ON; Y4 = OFF; G4 = OFF; active=1; } road2_go(){ R1 = ON; Y1 = OFF; G1 = OFF; R2 = OFF; Y2 = OFF; G2 = ON; R3 = ON; Y3 = OFF; G3 = OFF; R4 = ON; Y4 = OFF; G4 = OFF; active=2; } road3_go(){ R1 = ON; Y1 = OFF; G1 = OFF; R2 = ON; Y2 = OFF; G2 = OFF; R3 = OFF; Y3 = OFF; G3 = ON; R4 = ON; Y4 = OFF; G4 = OFF; active=3; } road4_go(){ R1 = ON; Y1 = OFF; G1 = OFF; R2 = ON; Y2 = OFF; G2 = OFF; R3 = ON; Y3 = OFF; G3 = OFF; R4 = OFF; Y4 = OFF; G4 = ON; active=4; }
setup(){ for(int cv=1; cv<13; cv++) pinMode(cv, OUTPUT); for(int cv=0; cv<5; cv++){ all_off(); delayms(700); all_on(); delayms(400); } loop(){ road1_go(); delayms(10000); blinka(); road2_go(); delayms(10000); blinka(); road3_go(); delayms(10000); blinka(); road4_go(); delayms(10000); blinka();
Step 2: Steps You Should Follow
Having your CloudX board and 12 LEDs(4 red, 4 green, and 4 yellow), connect the every thing as shown
1. Open the CloudX IDE,
2. Start a new project with an empty ,
3. copy the above code and paste it into the empty page,
4. compile and upload to your board.
