Making a Simple 2WD Rover Using an Arduino
Introduction: Making a Simple 2WD Rover Using an Arduino
About: #BnBe is a platform to help teach electronics no matter what the age or skill level. We’re currently designing a wide range of products from beginner level kits to industry-standard microcontroller platforms.
We continue our robotics adventures by making use of the theory that we learnt last week and building a simple 2WD rover using an Arduino.
Teacher Notes
Step 1: Watch the Video
The video above goes over everything you need to build this simple rover. This post will only provide the wiring diagram and sketch for you to use.
Step 2: Wire Up the Rover
You can use the wiring diagram above to connect everything together. Keep in mind that you may have to swap the motor wires if the motor rotates in the opposite direction. Please watch the video to learn more.
Step 3: Upload the Sketch
The Arduino Nano needs to be programmed in order for the rover to function. I have written a simple motor/rover driver library that can be used for your projects. You can download the library along with a demo file using the link below:
https://www.bitsnblobs.com/wp-content/media/diy/e41/e41.zip
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
