Making a Wooden Box Out of Cardboard
2,310
21
4
About: I'm a hobbyist maker who is trying to pass on something of the excitement and passion for making things in the hopes of inspiring others You can catch me on YouTube at https://www.youtube.com/channel/UCw2Og...
I had thought for a while that I wanted to make a cardboard box and apply veneer to the outside to make it look like a wooden box and when I saw the topics for this months competitions I decided the time was now.
Materials needed:-
Cardboard
Real wood veneer ( I bought an offcuts pack from ebay)
Glue ( I tried Wood Glue and CA but found CA much better, especially with activator)
Craft knife and / or Scissors
Hinges (if you want a hinged lid)
Paint (if you want to paint the inside
Please watch the video for additional hints and tips
Teacher Notes
Step 1: Step 1: Make the Cardboard Box
Firstly cut out the 4 sides to the size you want them
remember to allow for the thickness of the card
Glue the sides together, initially I used wood glue but it was difficult to hold together in the right position while it dried. I found CA glue with activator much better.
Make sure all of the joints are a square as you can get them.
Now Cut out the base and Lid to fit the sides.
Note: I did my lid later and it was much more difficult to fit because I'd already applied veneer to the box.
Glue the base to the sides using CA Glue and Activator
Step 2: Step 2: Add Veneer
When adding the veneer, I cut to an approximate size using scissors and then applied CA glue to the box and activator to the veneer. This worked well, allowing the veneer to stick firmly, you will see in the video that there were a couple of edge pieces where I did this the other way around, applying the glue to the veneer and activator to the cardboard.
When cutting the veneer, I found it best to use scissors for the vast majority of the cutting, saving only very delicate trimming for the sharp craft knife
When applying veneer, cut once piece at a time then glue on, do the sides before the tops and bottoms for the best end result.
Step 3: Step 3: Sand ( But Not Too Much)
When you applied all your veneer, you need to give it a good sanding for a night smooth box and good finish.
Note: Veneer is thin and it wouldn't be too difficult to sand all the way through so take care.
Step 4: Step 4: Apply Furniture and Finish
I used a couple of tiny brass hinges to give mine a hinged lid.
I painted the inside black rather than adding veneer to the inside
I used a Danish Oil finish to give it a little protection and to bring out the grain a little. You may also need to fill any small holes with a mixture of wood dust ( from sanding) and Wood Glue.
Step 5: Step 5: We're Done !!
So there we have it, a wooden box made out of cardboard.
Let me know if you made one or if you have any suggestions for improvements
Faux-Real Contest
Faux-Real Contest
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
    4 Discussions
    PaulChau
    8 months ago on Introduction
    I would really love to have a similar one but way bigger in size. It would really make a good storage solution or even double up as an ottoman. I'd just have to buy and install a neat piece of padding or cushion to make it work.
    serhardtPaulChau
    Reply 8 months ago
    To make it that big you would need strong cardboard ( which is possible) or use something like MDF for the basic structure and then cover with veneer
    attosa
    9 months ago
    Whaaaat.. that totally looks like wood :o
