Making the 6 Piece Notched Burr Puzzle
Introduction: Making the 6 Piece Notched Burr Puzzle
Hi! Its me Chinmay here. In this tutorial I'm gonna show you how the 6 pc notched burr puzzle can be made. Though this puzzle is very easy and has only one solution, it would be a great decoration for your table and would present you as a mastermind in puzzle-solving...
Teacher Notes
Step 1: The Diagramatic Representation.
For this you have to fetch a wooden log. The only condition in the log is that the breadth and height should be equal i.e. the smallest surface should be a square. The length of the log doesn't matter. For this project I have taken a log that's dimensions are b * h :: 3 * 3 cm. To start with, keep the block along 2 of its lengths and make the following design.
Draw the same design on just the front adjacent side inversely i.e. all the triangles should be on the inverse on the adjacent side but the starting triangle should touch the point from where the upper and first triangles started.
Step 2: Sawing the Piece
Next arm yourself with a saw and get ready to chop off those blocks. I'll prefer you to make a rough replica of the figure in step one on a new wood that is identical to the first. The trick is that after chopping the wood the cut-out piece would be shaped like a triangular prism. The rest of the piece would resemble a king's crown. When you'll measure the angle at the corner of each notch it will be 90°
Step 3: Smoothening the Piece
Then get a sand paper and scrub the wooden piece so that the small pricks don't pierce you fingers. Gently and gradually, it will have a great finish.
Step 4: Designing the Puzzle
This step purely depends upon your choice. You can make this puzzle black and white. Yes! You are right, this is the painting step. It is good to have it as a multi-coloured puzzle, but I prefer to give it a vintage look. Rub some thick eucalyptus oil on the pieces and watch how beautiful it gets.
Step 5:
Here is your own puzzle. Try to solve it on your own before reaching your hand for the solution. Thanks for giving this instructable your precious time. Till my next post Sayonaara! Goodbye! Adios! and Thanks!
Puzzle Challenge
Puzzle Challenge
Be the First to Share
    • Toys and Games Challenge
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    2 Discussions
    groverlohit68
    groverlohit68
    1 year ago
    I think that one more guy has made it write
    IXD JARVIS
    IXD JARVIS
    Reply 1 year ago
    I know that. but to overcome that fact I have written it in a better way with more easy steps that are easy to follow. Anyway please vote for me with your relatives as much as you can. The third prize and runner up prizes are great too but are aim is the Creality CR-10 3d Printer. The voting line is open till 14th December. So please be quick! Adios! Thanks!
