Mandalorian All Metal Replica Blaster
5,100
28
15
Introduction: Mandalorian All Metal Replica Blaster
About: I'm an inventor , artist, machinist , welder . Knife Maker , Blacksmith, follow me on Instagram at bonifabcustom or watch my builds on YouTube at Bonifabcustom
All made from either 1/4” flat sheet steel or 1/8” sheet steel , round tube rectangular tube and square tube
Supplies:
Parts are sand casted , tig welding machine, band saw and belt sander
Teacher Notes
Step 1: Research
Research was done by taking screenshots of the Mandalorian program then scaling was done
Step 2: Drawing and Scaling
A drawing was made to scale the parts so the front fork was made according to the drawing a template was made I cut the fork from plastic so I can use it as a match plate for a casting out of aluminum
Step 3: Casting
Then I made a casting out of aluminum by using the plastic part as a Impression
Step 4: First Part of the Body
To make the first part of the body I had to use numerous types of material the top rail was made from .750 by 1 inch solid bar the sides were made from 1/8” sheet metal and the bottom was made from bar also ,then I welded it together and to make the grooves on the top rail I pressed it in my ironworker
Step 5: Second Part After Front Rail
To make the second part in front of the front rail I made a template for the front then added quarter inch steel plate to each side after I cut it on the Band Saw drilled holes for the fake rivets made a top and bottom and then welded it together and ground it on the belt sander. And i used a piece of 1”x2” rectangular tube to hold it together
Step 6: Small Rail on Top of Second Section
After machining a small pocket on top of the second section I needed to make a small rail that fit into it so I made this from quarter inch flat steel then made two punches that impressed into it on the ironworker for the rail look
Step 7: Small Back Piece and Fake Tubing
A small back piece was made out of some flat stock and round tubing for the big radius ,then the fake tubing was made from quarter inch stainless steel bar and 3/16 stainless steel bar and they were bent to shape on a small bender
Step 8: Second Layer Partial Cover of Fake Tubes
To make the second layer the one covering the tubing partially was made from 1/8 flat steel and 1 inch 3/8 round tube for the radius Then welded together and ground down on the belt sander
Step 9: Stock Holder Clamp and Outside Emblem Base
The small stockholder was made from three-quarter inch square tube then cut on one side the outside emblem holder is made from quarter inch flat stock steel cut on the Band Saw then welded together
Step 10: Emblem
To make the emblem it was bent on the small bender out of quarter inch round bar then welded together then welded on some 18 flat steel sheets then ground smooth and then a nut was welded on the inside of the emblem and then it was mounted to the quarter-inch back plate
Step 11: Bottom Rail and Trigger Housing
For the bottom rail it was drilled and tapped on to the bottom it was made from three-quarter inch square bar and the trigger was made from 1/8” steel and quarter inch steel plate welded together made from a cut out template . The trigger was then made from 3/8 steel cut and polished to fit the body
Step 12: The Stock Housing
The stock housing was made from multiple pieces of 1/8 sheet metal welded and ground together to fit the blaster
Step 13: Wooden Stock
The stock was made from a template then cut from black walnut on the bandsaw and then put on the belt sander to smooth out the edges and then was finished off by fitting into the blaster then some Tongue oil was applied
Step 14: Triangle Bottom and Scope
The bottom triangular part underneath the fork was made out of aluminum billet then welded to the bottom of the Fork holder the scope was made from 1 inch thick wall tubing then turned on the Lathe to look like a scope small pieces of plastic were installed for the look of the site glass
Step 15: Scope Holder
For the scope holder it was made from billet aluminum machined on the Milling Machine then fitted into the gun and held in by a quarter inch screw
Step 16: Barrel Holder and Fake Rivets
Next the barrel holder brackets were made from round tubing then welded together and then ground on the belt sander for the fake rivets they were installed using epoxy glue
Step 17: Put Together and Finished
Final assembly was done some polishing and some small paint accents like gold on the emblem and gold for the fake tubing
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    15 Discussions
    francis_riodique
    francis_riodique
    5 days ago
    Awesome,this is my first time to see a great piece of work that is used in a scene. Thank you.
    Bonifabcustom
    Bonifabcustom
    Reply 5 days ago
    Your welcome 👍
    ChrisW311
    ChrisW311
    6 days ago
    very well done, you are very talented. I just wish Americans would get their heads out of the sand and use metric measurements.
    Bonifabcustom
    Bonifabcustom
    Reply 6 days ago
    Thankyou much appreciated
    mrbuddyroberts
    mrbuddyroberts
    6 days ago
    I am not sure what the materials cost on this or how much time it took you to make this, but I am betting that there are more than a few folks out there who would be very happy to pay you to recreate that amazing work of art for them. I'm currently 3D printing one though right now I'm feeling a little like a finger painter talking to Picasso.
    Bonifabcustom
    Bonifabcustom
    Reply 6 days ago
    Thank you , it took about a month to make , not very much in raw materials but a lot of time in the details , thanks
    ka3ros
    ka3ros
    6 days ago
    \o/ °o° \o/
    Master of Blaster
    Bonifabcustom
    Bonifabcustom
    Reply 6 days ago
    Calamitosity
    Calamitosity
    6 days ago
    That's awesome! I bet it weighs a ton!
    Bonifabcustom
    Bonifabcustom
    Reply 6 days ago
    Thanks , it’s not to bad it weighs 22lbs
    Mr Joshua
    Mr Joshua
    6 days ago on Step 17
    That's amazing work, thanks for sharing!
    seamster
    seamster
    7 days ago
    Whoa, this is wildly impressive and inspiring!! Huge amount of skill on display. Thank you for sharing your process : )
    Bonifabcustom
    Bonifabcustom
    Reply 7 days ago
    Thank you very much . We are making a IG-11 from the Mandalorian on Youtube now check out my build it just started.
