Map Bookcase
About: As a stay at home mom for the past 15 years I decided to be creative in turning old things into new!
Supplies paint for item, map, mod podge, foam brushes, bowl for mixing mod podge in lots of paper towels
Teacher Notes
Step 1: Choose Your Project to Map
I choose a microwave cart that was ugly. I then sanded it and painted it light blue on the areas that were not going to have maps on it. Let it dry completely for 24 hours.
Step 2: Mod Podge the Map
This is my first attempt with mod podge. I watered it down so as not to rip the map, I first coated the top of the microwave cart then "glued the map to the top". I let it dry completely before going to the next step.
Step 3: Mod Podge the Top
After I glued the map in place and it was completely dry which took 24 hours, I mixed the mod podge 3-1 ratio. I then added a thin coat on top of the map.
Step 4: Add a Map to the Back Wall of the Shelf
I glued the map to the back wall in 2 pieces as there is the shelf dividing it. I laid the cart down to make it easier to attach it. Let it dry 24 hours
Step 5: Adding a Round Globe Picture to the Shelf
The shelf seemed plain so I found a round earth picture with my map and glued that (with the mod podge) to the center. Let dry 24 hours.
Step 6: Finishing Touches
Now all maps have been secured I went back and applied the mod podge to each one, allowing 24 hours to dry. I settled on 2 good coats on the shelf and back wall and 3 coats on the top to add durability!
Maps Challenge
Maps Challenge
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Multi-Discipline Contest
    seamster
    4 weeks ago
    Great way to refresh an old piece of furniture. Thank you for sharing! : )
