Marble Cannon
Introduction: Marble Cannon
Gather Supplies
  • 50cm x 50cm wood board
  • 45cm PVC pipe
  • 18cm PVC pipe
  • 45cm wooden dowel rod
  • 2 springs
  • Hose clamp
  • 2 tube straps
  • 3 25cm tall wood blocks
  • 2 hooks
Teacher Notes
Step 1:
  • Connect the 3 wood blocks to the wooden base using wood glue and screws.
Step 2:
  • Using the tube straps, drill the short PVC pipe into place loose enough to spin on top of the wood blocks.
Step 3:
  • Using another strap, drill the long PVC pipe onto the small one so that the angle of the cannon can change.
Step 4:
  • Drill a hole at the end of the wooden dowel and put in a metal rod through it.
  • Add nuts to hold the metal rod in place as well as connect one end of each spring to the wooden dowel.
Step 5:
  • Use a hose clamp to connect hooks and springs to the PVC pipe.
Step 6:
  • All done!
Step 7:
The calculations show
  • Time launch took
  • Initial velocity using kinematic equations
  • Force using work-energy equations
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
